Old 09-18-2010, 01:51 AM   #1
atsronnyats
atsronnyats is on a distinguished road
stranded again what gives? ideas
took the na s4 fc vert out last night for late night drivethru withdrawal, so as per usual i turn the car off to talk to the clown while waiting 4-5 mins i try to crank back up.....miss it (i have to wait for stater to stop) then try again once engine is once again turning over she decides thats all she will do. i cant remember exactly (rough night towed the fc home) but i do think there was a intermitent start there for a couple seconds not sure this is the point where i tried to restart. so yeah im pushing the 7 thru the drive thru get my drink and by a simple math error im only charged for what my girl ordered lol that did help at the time. got the (Free) food and attempt to push start it. it does start but has no ablity to accelerate i e no throttle responce at all. a dies and soon as the rpms die with it. i thinking flooded? i always think that lmao. so i pull the plugs they are dry of oil gas nada... with so black discoloration no ash or carbon deposits but black ya know. i went thru the rigoris deflood procedure with no luck it just turns over. so im thinking i wasnt getting fuel.
OK here is the kicker after driving the minivan to work i get home and for shitz and giggles decide to try and start it. she offers no problems at all , first attempt fires right up to the 3k warmup.... i cant fix when i do have a problem only trouble is there is a problem? the 7 is messing with me ideas neone
btw i am a noob to this forum, came from rx7club recently ATL based
atsronnyats is offline   Reply With Quote
Old 09-18-2010, 03:10 AM   #2
that's a lot going on in one post.
RIght away sounds like a hotstart issue and severe flooding...
1. What's the mileage on the car? How old are your fuel injectors? Have they ever been replaced?
2. When was the last tune up (i.e. plugs, wires, make sure the TPS is set right and no flatspots, timing is dead on)?
3. the way you described the car dying when you give it throttle input makes me think you may have some sort of vacuum leak...have you checked for vaccum leaks?
I recommend you videotape the next time this happens so we can see it...your posting style is difficult to read.
Old 09-18-2010, 05:17 AM   #3
Fuel filter?
Old 09-18-2010, 01:25 PM   #4
atsronnyats
1.yea all have been changed as of late in miles... as for miles 110k on the car
2. i have replaced all vacuum hoses
3. reconditioned the injectors not long ago (2 & 3 done at same same time)
4. i do have replacement wires and plugs ready to go havent changed bc dont think its neccesary but i am asking yes
5. i guess i could replace the fuel filter i work at advance auto parts will pick one up today
6. changed the fuel pump the first time i had problem like 2k miles ago
7. i had extra coils changed them under the belief it was a spark issue
Old 09-18-2010, 01:33 PM   #5
atsronnyats
i just got this car back from when it stranded me in florida luckily at my parents house.
the same moved the car to load my stuff up switched car off. then no restart and failed attempts to push start parked it had it "fixed" got it back a couple weeks ago
since then a idle has never been established... got it to where i can drive it... stopped with the ac running does present a problem also cold starts car will stall
-if any of that information helps
Old 09-18-2010, 04:40 PM   #6
13brewrx3
13brewrx3 is on a distinguished road
I had pretty much the same problem. would start cold and drive fine but seemed very sluggish till I shut it off. changed all the things mentioned above and nothing helped. I had the compression checked and found out I had low compression in both rotors. The only difference I guess is I was able to pop start mine(i dont know if this matters). From what Im reading you arent able to do this? I may be way off but have the compression checked
13brewrx3 is offline   Reply With Quote
Old 09-18-2010, 10:43 PM   #7
atsronnyats
i dunno what checking the compression would help honestly only because it "works" fine but has a mysterious hot start issue...definately something i would think to check....and honestly something ive never checked on a rotary...will check fsm
Old 09-18-2010, 10:54 PM   #8
atsronnyats
i love the fact the fsm always uses special Mazda specialty tools i give my left nut for i.e. the compression tester as seen in the fsm anyway its mentions checking all THREE combustion chambers(gotta love it)NOTE: should read 85psi or 588kPa consistantly @250 rpm and list a variance ceiling (limit) of 21psi or 147kPa although it does vary with rpm it mentions has a cool XY chart
just a fsm rant thought id mention it
still wish i had the tool lol
Old 09-19-2010, 01:47 PM   #9
LunchboxCritter
Simply Rotarded
LunchboxCritter's Avatar
Have you checked your fuel pump wiring?
You can check your compression with a standard compression tester. Here is an example, you can search youtube for other examples.
http://www.youtube.com/watch?v=DMflTrwgKss
LunchboxCritter
- 91 NA to J-Spec TII
- 88 FC Vert
- 04 Rx8
DO NOT TRY THIS AT HOME!!!
Old 09-19-2010, 07:17 PM   #10
atsronnyats
there you go lunchbox....got the stethoscope out no sounds up front when inspecting the fuel pump in back again nothing....so yes a fuel issue definatly changed the filter anyway...
it got dark on me didnt have time to get the multimeter out will break it out tomorrow
btw it did the same thing...cranked right up but died out because it wasnt warm due to bad idle....it did this two more times before it ran and just died out and yeah the final time as if it abruptly lost fuel, trying to start from this point yielded the same results as before
the car was low on oil theres no fail safe is there cutting out out power to the pump?
Old 09-20-2010, 10:25 AM   #11
LunchboxCritter
Simply Rotarded
I do not believe that there is a fail-safe based on the oil level.
The pick up screen in the tank could be getting clogged up, so you might check that while you're checking the internal wiring to the pump.
I would recommend running new wires to your fuel pump, and definately make sure that you have a good ground for your fuel pump. There are some pretty good write-ups about how to do it; however, I'm fairly sure it's pretty straight forward as you're just replacing old wire with new, and securing a better ground.
LunchboxCritter
- 88 FC Vert
- 04 Rx8
Old 09-20-2010, 10:47 AM   #12
atsronnyats
Good stuff man this stuff is old as I am any way will check the stickies and go from there....
Old 09-20-2010, 01:47 PM   #13
The only "fail safe" it has is that the idiot cluster will light up for low oil and the buzzer will go off. The same buzzer for redline/low coolant.
A car with low compression will still "work" very well, it just won't pull as hard, but you'd probably never notice that. Low compression really begins to cause issues with things like hot start and idle.
Old 09-20-2010, 05:35 PM   #14
atsronnyats
[comments removed]
Old 09-20-2010, 05:41 PM   #15
atsronnyats
1. all good to know. will check into i have a friend in mind with tool
2. still have the rewire (fuel Pump) to do im reading up on the for NA. also decided to change the fuel hoses/clamps didnt like the condition
