Old 09-01-2010, 03:57 PM   #1
sen2two
KTEC
sen2two's Avatar
Good bye wheel hop, Hellooo quick 60's
This is how you get rid of wheels hop for 6k+ launches!!!
Even the Mazda competition mount sucks. So what i did was take my factory one. Which was broken of course. Sand blast it clean then trim off the front piece. Then weld in thick steel bracing to make i truly stiff and UN-BREAKABLE!!! You don' need a TIG to do this. You can easily MIG it with no problem. I just prefer TIG for everything.
I also did this because i swapped out my tired old NA diff for the world famous TII s4 diff. S4 diffs, are the strongest of all Mazda factory rear ends. Then added solid rear diff mounts and a pinion snubber. Good bye wheel hop...
what I have:
What I had:
Old 09-01-2010, 04:00 PM   #2
sen2two
KTEC
sen2two's Avatar
I also added soild tranny and motor mounts. I will be making a brace for the motor to keep it a little stiffer. I want all slack and slop removed from the drivetrain.
I have a small goal of breaking into the 12's with stock motor, turbo, ECU, ect. ect. ect. Getting off the line is key here for me.
what I have:
What I had:
Old 09-01-2010, 04:41 PM   #3
Boosted FC
Rotary & Boost Addict
Boosted FC's Avatar
Boosted FC is on a distinguished road
Looks really good. Would you be willing to do this for anyone else?
'05 Copper 6s, '87 TII RX7...248whp & 224wtq @ 12lbs
Boosted FC is offline   Reply With Quote
Old 09-01-2010, 06:20 PM   #4
sen2two
KTEC
sen2two's Avatar
I could. You can PM me if you are interested...
what I have:
What I had:
Old 09-01-2010, 09:14 PM   #5
I've NEVER had wheel hop issues @ 400whp. I'm also skeptical of a diff mount stopping wheel hop when there's no direct/solid connection between the diff and the wheels.
I think you're feeling the diff smack the undercarriage and confusing it with wheel hop.
Old 09-01-2010, 09:29 PM   #6
sen2two
KTEC
sen2two's Avatar
I had video of the wheel hop. No confusion here...
Your a lucky fella then. Just about all of my FC's had wheel hop. Most other owners are plagued with it also. I think the reason you dont have wheel hop is you either have a good suspension set-up, solid mounts already, or just spinning the tires.
Now, not all FC's in the world will get wheel hop. But this is not my first FC. This is also not the first time i have cured wheel hop.
what I have:
What I had:
Old 09-01-2010, 09:33 PM   #7
josh18_2k
thats gonna break the mounting tabs off the subframe. only a matter of time...
the front diff mount needs some method of damping vibrations, other than metal fatigue
Old 09-01-2010, 09:42 PM   #8
sen2two
KTEC
sen2two's Avatar
I am not the first to do this I'm sure...
There are people running 8's and 9's on the factory TII rear. You think they did that with the Mazda mount? No way...
To break the mounting tab off the sub-frame there would have to be slop and movement in the drivetrain. I will have as close to zero slack in the drive train as physically possible with the stock drivetrain. IF the mountuing tab did ever break, which i doubt. I will beef that up also.
what I have:
What I had:
Old 09-01-2010, 09:57 PM   #9
RotorDad
Big Ugly
RotorDad's Avatar
I have seen a few FC's with some pretty bad wheel hop in the past, how have these worked out for you? On my Spec V, yes it FWD we use solid mount or poly inserts to help aid with wheel hop. Soft mounts no good!
Boosted Big Body On 335's
PS3 ID: Rotordad
Old 09-01-2010, 10:50 PM   #10
Nismo
400WHP or bust
Nismo's Avatar
I did this years ago, it worked, but like mentioned above I ripped the mounts off the sub-frame, I beefed that up with some angle, been good for 2 years. But with a pinion snubber, you shouldn't have wheel hop... What are your tire pressures, and suspension set up?
Old 09-01-2010, 10:55 PM   #11
sk8world
600rwhp club member.
mt et streets = no wheel hop.
6.? @ 11? drag pass
http://www.youtube.com/watch?v=9wfxT2RMr7c
Old 09-01-2010, 10:55 PM   #12
sen2two
KTEC
sen2two's Avatar
Tire pressure is 30psi on 255/40/17 Falken Azenas with Rays Gram light 57s.
But all this is being done because I will be running the car on a set of 15x8 Weld pro stars with 26" tall slicks, with skinnies up front. Starting at 15psi rear wheel tire pressure, and adjusting from there.
what I have:
What I had:
Old 09-01-2010, 11:44 PM   #13
antman0408
antman0408's Avatar
antman0408 is on a distinguished road
I've always had wheel hop in my car, and its the worst when I'm launching at the track. I even put in a pinion snubber and still get it. It reduced hop some but not all.
Good luck to you on hitting 12s. I'm kinda have the same goal, 12s with the stock turbo. With a good launch, I think I'll get it.
antman0408 is offline   Reply With Quote
Old 09-02-2010, 12:14 AM   #14
+1
To the OP: you're giving yourself too much credit
This is not about slop.
It's about torque transfer.
Regardless of slop, that kinda torque transfer is going to...torque...something.
You just moved the weakest link from the front diff mount to the sub frame.
Have fun fixing that when it breaks...
Old 09-02-2010, 12:57 AM   #15
RotorDad
Big Ugly
RotorDad's Avatar
Wheel hop is not good for drivetrain parts so getting rid of it is a plus. Running a slick doesn't always solve the problem, I'm sure that most of us have seen cars running slicks have terrible tire shake. BTW running a slick & dead hooking will induce more stress on drivetrain parts. A progressive spin will cause slower times, but will be easier on parts. Sometimes while fixing one problem we just move the problem somewhere else, so making a decision pros over cons comes to play. The more power achieved may reintroduce wheel hop once mods have been done to correct the previous problem. If everyone is worried about braking stuff I suggest that you don't race your car. Shit happens from the weekend racer to the pro level teams.
PS3 ID: Rotordad
