Old 08-30-2010, 09:06 PM   #1
tweiss3
Mazda Lover
tweiss3's Avatar
Need some help diagnosing this code
91 non turbo. Code is 09
From what i can see that is water thermo sensor. I just replaced the thermo sensor with mazda OEM to get rid of this code. What else could it be. Yes i disconnected the battery.
Old 08-31-2010, 06:06 AM   #2
RotaryDiagnostics
Compression Tester Man
RotaryDiagnostics's Avatar
Check for continuity or shorts in the wire from the sensor to the ECU. Check voltage at pin 2E of the ECU according to the factory service manual.
Old 08-31-2010, 06:41 AM   #3
tweiss3
Mazda Lover
tweiss3's Avatar
thanks, ill give that a shot. What page and section in the FSM was that?
I was agrivated that the FSM skipped troubleshooting code 09
Old 08-31-2010, 09:14 AM   #4
check the connector too. I know a few instances where a pin backed out causing an open circuit.
Old 08-31-2010, 08:46 PM   #5
tweiss3
Mazda Lover
tweiss3's Avatar
FerociousP, you are awesome. It was the connector, the pin backed way out. Now she starts in like 2 seconds instead of 25 seconds. And NO CODES, horay. Thanks for the quick responses everyone. Now on to titling it and registering it
Old 09-01-2010, 07:24 AM   #6
Boosted FC
Rotary & Boost Addict
Boosted FC's Avatar
Boosted FC is on a distinguished road
RCC ftmfw!!!
'05 Copper 6s, '87 TII RX7...248whp & 224wtq @ 12lbs
Boosted FC is offline   Reply With Quote
