Old 08-20-2010, 12:48 AM   #1
FrankV702
FrankV702 is on a distinguished road
WTB: Stock turbo water lines with banjo bolt + more miscellaneous parts
Hey what's up guys.. I need some miscellaneous parts
I need the two stock banjo bolts with stock banjo fittings for the stock turbo water lines from either an S4 or S5 turbo..
Also, I need the bracket that bolts/grounds the trailing coil to the chassis. I have the piece of the bracket that has the rubber snubber on it, I need the bracket that bolts to that, then to the passenger side strut tower, and finally to the two bolts on the botton of the trailing coil.
And I need a stock fuel pump strainer with the rubber piece that goes on the bottom.
I need these parts ASAP if anyone has a box of extra stuff lying around.. I have cash in hand and/or parts to trade.
Let me know what you have with a price shipped to N.LV NV 89031..
Thanks,
Frank
FrankV702 is offline   Reply With Quote
