Old 08-11-2010, 07:57 AM   #1
Aees
Aees is on a distinguished road
BNR Turbos, sheets and engine spec plz!
Hi, im new to this page and am just starting to mod my 90 EU TII vert.. And I am trying to suck up as much info as possible about how to do this right. Could you guys with BNR turbos write down your engine spec, BNR stage and maybe some dynosheets? I have a 3 inch straight exhaust, FCD, stock primaries, 720cc secondaries, walbro fuel pump and FMIC. For this winter I probably be buying a koyo rad and a Apexi PFC. Then when the economy allows it I will rebuild my engine and do a street port. When that time comes the big question will be; "what turbo".. Awesome forum btw, thanks guys!
Aees is offline   Reply With Quote
Old 08-11-2010, 12:07 PM   #2
Dzire
Dzire's Avatar
Dzire is on a distinguished road
here is a link of my dyno run on a stage 2 Bnr
http://rotarycarclub.com/rotary_foru...ad.php?t=11769
RX8 2004 GT
RX7 1988 TII
Dzire is offline   Reply With Quote
Old 08-11-2010, 03:08 PM   #3
Aees
Wow, u put down some good numbers there. I didnt know you could get that much HP with 2 1/2" downpipe, stock ports and 720 secondaries! Good job man. I guess your car is really fun to drive, with no turbolag and good response. I am thinking about doing the stage 3 BNR with a pfc and streetport. I think the streetport will help much on spooling the turbo and I will have a nice powerband and put down 350+BHP. I want a engine with good response without turbolag and only power at the last thousand RPM`s. Will the stage 3 be too big for that? I will boost 15psi i guess..
Old 08-11-2010, 05:57 PM   #4
Your fuel injectors are not big enough.
Old 08-11-2010, 06:13 PM   #5
sen2two
KTEC
sen2two's Avatar
350+ will require a lot of fuel. I made 409whp on an older TII of mine with a 255lph fuel pump, 720 primaries and 1680 secondaries at 14psi. The only reason it stopped there was because there wasn't enough fuel to go any further. Now the injectors them selves were good until a little over 500, but what are you doing for a fuel pump?
Also, with stock primaries and only 720 secondaries... your pushing it at 300whp. and pushing it hard. Anything over 80% duty cycle on your injectors is not a good thing. So just because you can run them at 90 or 100% duty cycle with a standalone, but that dosn't mean you should.
I would at a minimum, get 1000cc secondaries for a 350whp goal. But that's only because I use methanol as an additive. Without any AI, just get some 1680's Bosch style. they drop right in to the stock fuel rail.
what I have:
What I had:
Old 08-12-2010, 05:12 AM   #6
Aees
Ofcourse im gonna get some bigger injectors. The reason i am having 550 pri and 720 is because im just having FMIC, straight exhaust and open filter.. As soon as im getting a pfc, streetport and so on im gonna upgrade my fuel system.. You guys have any input on the BNR turbos? Did you have a BNR turbo when u made 409whp?
Old 08-12-2010, 06:15 AM   #7
RotaryDiagnostics
Compression Tester Man
RotaryDiagnostics's Avatar
BNR Stage 1
Here's a sheet from a recent dyno run. Car has a BNR Stage 1 turbo, 750cc RC secondaries, 3" RB REV-II turbo-back exhaust system, Supra TT fuel pump, Bonez intake, and Apexi S-AFC II tuning.
Tried the Rtek 1.7 chip, but the tuner could not get a safe AFR, so had to revert to a stock ECU and rely on the S-AFC for tuning. Engine runs awesome on the track. It does have an intermittent starting problem and a bit of a rough idle, which I will address during the off season. May try chipping a different ECU.
Old 08-12-2010, 01:02 PM   #8
Aees
Thanks for uploading your sheet. Funny track car i believe I guess this proves you can have much fun with a FC with just minor modifications. How much boost did you run?
Old 08-12-2010, 04:55 PM   #9
You can fun in a stock N/A FC...
Old 08-12-2010, 05:12 PM   #10
RotaryDiagnostics
On the track about 9-10 psi in hot weather.
Old 08-14-2010, 01:56 PM   #11
Aees
Okay, is there anyone out there with a BNR stage 3 or more with a stage 2? It`s between the 2 or 3 for me now i think.
Old 08-16-2010, 04:13 PM   #12
LunchboxCritter
Simply Rotarded
LunchboxCritter's Avatar
Stage 3 is the same price with bonus's. I'm guessing between the two it's the best bang for the buck.
LunchboxCritter
- 91 NA to J-Spec TII
- 88 FC Vert
- 04 Rx8
DO NOT TRY THIS AT HOME!!!
Old 08-17-2010, 02:46 AM   #13
Aees
It has a larger compressor wheel. Will that hurt spool-up? I will rather have response than 40HK extra.
Old 08-17-2010, 05:57 AM   #14
88turboii
destroy, rebuild, repeat
88turboii's Avatar
i had stage 3 and couldnt get much more than 300whp out of it. if i were you i would get stage 4, but ask for unclipped p-trim wheel. you may get a little creep, but its not too bad, makes up for it in spool.
whtever happend to BNR vendor section?
Old 08-17-2010, 07:58 AM   #15
JerryLH3
JerryLH3's Avatar
JerryLH3 is on a distinguished road
Are you running the stock TMIC? Just curious, as it looks like your setup will be similar to mine in many regards once I get to the performance stuff after I finish the paint and body.
Jerry
1991 Mazda RX-7 Turbo - the current project/money pit
JerryLH3 is offline   Reply With Quote
