Old 03-25-2008, 12:37 AM   #1
Twins
Twins is on a distinguished road
greddy catch can
hey guys i just purchased a greddy catch can and i need help installin it. just wonderin where do you guys connect the lines?? also if you have pics of your setup that'll b great. thankz sorry this is for my fd
Twins is offline   Reply With Quote
Old 03-26-2008, 04:34 PM   #2
Signal 2
Viable Fossil
Signal 2's Avatar
http://reganrotaryracing.tripod.com/catch.htm
Jim
VR R1 FD
Old 03-26-2008, 06:10 PM   #3
dhays
dhays is on a distinguished road
Twins, I've had the same question and looked at the link you were given. I'm afraid I'm not smart enough to figure it out from that. So, when you do, please take some photos of your install and share. I want to install a catch as well.
Dave
dhays is offline   Reply With Quote
Old 03-26-2008, 07:14 PM   #4
Twins
is there a breathable and a not breathable?? the greddy catch i purchased doesn't have a lil filter on top of it. it actually doesn't have any hole to breath out of it. will it b installed differently?? looks like this http://images.google.ca/imgres?imgur...%3Den%26sa%3DN
Old 03-26-2008, 09:32 PM   #5
busted7
busted7 is on a distinguished road
One line goes to the oil fill pedistal nipple and the other goes to the intake ahead of the turbo. This will take pressure or blow by from the crank case and deposit oil particals in the catch can and is aided by the vacumn effect of the intake pulling vacumn. Then you watch the clear tube and when the oil level starts getting higher drain it. I belive you use the pcv nipple on the oil fill and eliminate the pcv valve.
busted7 is offline   Reply With Quote
Old 03-26-2008, 09:43 PM   #6
0110-M-P
Avid Installer
0110-M-P's Avatar
0110-M-P is on a distinguished road
Never put on on a rx7 but I have always placed the oil catch can in line with the pcv valve with no breather. Always worked well for me.
1993 T04Z BB RX-7
1983 RX-7 GSL
M-P Racing
Project Blog
0110-M-P is offline   Reply With Quote
