Go Back   Rotary Car Club > Vendors and Group Buys > All Vendors > Garfinkle's Motor Works
Garfinkle's Motor Works garfinklemw@gmail.com (TN) Custom products for 3rd Gen RX-7's
Old 07-08-2010, 03:13 PM   #1
Garfinkles Motor Works
Replace the oil returm line with JIC fittings and braded line
I made this set for a customer to replace the stock oil return line .The price will be set at $25 per part .The flange is EDM cut 3/8 steel and the JIC fitting is brazed in and the flange is counter bored for better flow .
Old 07-15-2010, 06:06 AM   #2
Finally!! Answers to my nightmare when I install turbos.
David, I'm definitely wanting these!!! Please sign me up for 2 sets!
Old 07-15-2010, 08:14 PM   #3
I will make them asap
Old 08-11-2010, 08:56 AM   #4
Awesome!
Old 08-18-2010, 06:39 PM   #5
hades
per part - or per set of 2?
This is going to tear
Old 08-19-2010, 05:46 AM   #6
per part... set would be $50.
Old 08-19-2010, 09:58 AM   #7
That is correct each fitting is $25 ,a stock motor with twins will need four fittings to replace both return lines .The customer that has the first set said he will post a write up on this .
Old 08-31-2010, 10:47 AM   #8
Drama
Drama's Avatar
Drama is on a distinguished road
I need only one, Am going to a single. Whats your Paypal.
10th A.E. with 94 Twin Turbo FD Engine, With a precision turbo SC 60. Tokico Blues, B & G springs, Racing beat sway bars, Fender braces, F & R strut braces, Stainless brake hose`s, Toe eliminator busings, Carbon/Kelvar GT300 hood, Depo Gauges,Catz fogs,Sparco 383 steering wheel, 3rd gen shifter knob.
Falken Anzenis Rt 615`s
Front wheels 17X8+35 245/40
Rear wheels 17X9+44 with 5mm spacer 275/40
Drama is offline   Reply With Quote
Old 08-31-2010, 01:33 PM   #9
Paypal is garfinklemw@gmail.com Shipping by USmail is $5 pey pal is $.90
Old 09-03-2010, 08:15 AM   #10
Drama
Drama's Avatar
Sending it through now $31.00
Old 09-04-2010, 02:13 PM   #11
Shipped today and thank you
Old 11-28-2010, 10:11 AM   #12
ball joint
ball joint is on a distinguished road
What size AN fittings would you use to make the oil lines for these fittings?
ball joint is offline   Reply With Quote
Old 11-30-2010, 01:05 AM   #13
# 8
Old 03-27-2011, 12:50 PM   #14
Can you do something like this for the series 5 FC?
Old 03-27-2011, 10:19 PM   #15
I will need to have a stock gasket to see if it is the same as FD.If it is not the same then I would need to write a new set of programes to cut the plate on the EDM .
