Old 03-24-2008, 02:16 AM   #1
a7xh7
a7xh7 is on a distinguished road
2 questions, clutch bleeding
1. what is the endpoint of clutch bleeding? seems like ive tried FOREVER to bleed my system. not sure when its done? its bled to the point where i am no longer seeing any more changes in the pedal.. but has about 3 inches of "slop" where it does nothing. push it further then it will start to disengage the plate. im i done with bleeding and just need to adjust the pedal?
2. is sealant used for piping leading into the clutch slave? im not sure if it has a tiny leak there, what can be done if it is leaking at this junction? its properly torqued and the threads are lined up correctly..
a7xh7 is offline   Reply With Quote
