Old 03-23-2008, 08:42 PM   #1
banzaitoyota
banzaitoyota is on a distinguished road
Optimal Fuel System setup for carbs?
What is everyone running?
My deuce
banzaitoyota is offline   Reply With Quote
Old 03-24-2008, 05:17 PM   #2
repu510
repu510 is on a distinguished road
running Weber 48IDA on the 510 and stock Nikki on REPU
repu510 is offline   Reply With Quote
Old 03-24-2008, 05:26 PM   #3
banzaitoyota
I was thinking more the rest of the system, other than the carb.
I currently have a unknown modded prepped NIKKI/ Mr, Gasket pump/ Fuel Cell
My deuce
Old 03-24-2008, 05:56 PM   #4
orion84gsl
Waiting for my Sterling to come in, Carter 7LB pump(not on yet, this weekend hopefully) Holley 1-4PSI regulator. Going to try to modify my stock intake to flow a little better, but will be buying a spare, because I'll most likely screw it up.
Old 03-30-2008, 11:11 PM   #5
jtbshaw
ORD - Old Rotary Dude
jtbshaw's Avatar
On my last 13B bridge-port setup, I was running a RB 650 DP carb, Aeromotive A1000 pump, System 1 billet filter, Mallory 4309 rising rate regulator, -10 supply braided line and -8 return braided line. This system also pumped the fuel for the 100-150 shot of N2O wet/plate system.
Old 03-31-2008, 10:25 AM   #6
tom93r1
tom93r1 is on a distinguished road
I have a Carter pump that needs to be installed, dont remember which model number. Its the 6psi, 72GPG one. Going to dead head it into my Weber, as webercarbs.com recommends.
tom93r1 is offline   Reply With Quote
Old 04-01-2008, 12:37 AM   #7
FC Zach
FC Zach's Avatar
Aeromotive pressure regulator, 6AN lines and fittings, and Chevy TBI style fuel pump. Went with this fuel pump because it's an in-tank pump, easily accessable, cheap, and fuel pressure on TBI pumps are low enough to be regulated. (I think I remember it being around 12 psi) You must use a bypass style regulator since the pump holds pressure after shut off like any other EFI pump.
Old 04-02-2008, 07:20 PM   #8
Kentetsu
Kentetsu's Avatar
Carter pump w/Holley fpr. Then I added a fuel pressure gauge from Respeed (highly accurate, and dirt cheap).
Here's a writeup I did on my installation, with lots of input from others, posted over on the "evil forum". http://www.rx7club.com//showthread.php?t=529605
Old 04-12-2008, 07:42 AM   #9
moremazda
shookmotorsports.com
moremazda is on a distinguished road
48 DCO, Aeromotive FPR, Walbro GS394 inline
64 F9 idle
185 main
F11 emulsion
cant recall the main air
3.0 needle and seat
3 psi fuel pressure
The car is a first gen with a 13b
moremazda is offline   Reply With Quote
