| RX-7 1st Gen Specific (1979-85) RX-7 1979-85 Discussion including performance modifications and technical support sections |
#1 |
Rep Power: 0 ![]() |
plugs a little white, when i pulled them out?
i have an 84 gsl se 1.3 resi, i pulled my plugs and the are a little white. how do you add more fuel with the fuel injection, and which plugs should i be using?or am i having a different problem all together? please help me out! thanks
#2 |
Rotary since 1972
Rep Power: 18 ![]() |
Depending on the whiteness you could be fine. As long as your exhaust temps are OK and you are not over heating I wouldn't be too concerned.
You can richen it with the mixture control. Located just aft of the air filter box. It is a recessed screw in a brown case. There were two curved arrows also showing an L and R. It does not take much to make a drastic change. If you really have to do it in slot sized increments. In lieu of that you could add a little Redline Two stroke race oil also. That would richen it up. |
| Bookmarks |
