Go Back   Rotary Car Club > Vendors and Group Buys > All Vendors > Garfinkle's Motor Works
Garfinkle's Motor Works garfinklemw@gmail.com (TN) Custom products for 3rd Gen RX-7's
Old 06-21-2010, 01:59 PM   #1
Prometheus
Prometheus's Avatar
Prometheus is on a distinguished road
Any interest in developing an individual coil ignition system?
I think an individual coil ignition sustem (using GM or other readily availabe coils) would be an awesome product to add to your already bad ass line-up.
is there enough room to move all 4 coils to the frame rail, like your relocation bracket you already offer?
Prometheus is offline   Reply With Quote
Old 06-21-2010, 07:42 PM   #2
If you're serious about this, wait a few weeks until after I test a few coils. My gut tells me some of the GM coils are pretty weak and there are alot of better choices out there.
Old 06-21-2010, 10:43 PM   #3
Prometheus
Prometheus's Avatar
I'm serious, I'm trying to convert as much expendable components over to domestic/ more readily available parts.
as these cars get older, they will be harder to find good quality parts for locally.
Old 06-22-2010, 07:12 PM   #4
Garfinkles Motor Works
My car has four Jabcobs C4 coils mounted on the finder side below the 929 brake master cyl .
Old 06-23-2010, 08:38 AM   #5
t_g_farrell
Waffles - hmmm good
t_g_farrell's Avatar
I went with 2 GM 4 prong HEI ignitors and 2 Ford TFI coils for my leading ignition and dropped the trailing. Works great.
Old 06-23-2010, 08:39 AM   #6
t_g_farrell
Waffles - hmmm good
Yes thats exactly why I went with the GM HEIs and the Ford TFI coils. I can
replace those from any AutoZombie shop in the world if I have a failure.
Old 06-24-2010, 08:19 AM   #7
How often do coils fail? I would rather replace the coils to get a stronger spark, not becuase they have a high failure rate.
Old 06-24-2010, 08:35 AM   #8
The C4 coils are rated at 65 k volts plus I am using an AEM twin fire ignition module to fire them .
Old 06-17-2012, 01:50 PM   #9
ka24det92
ka24det92 is on a distinguished road
i am interested in your ignition set up could you tell me more about it
ka24det92 is offline   Reply With Quote
Old 06-17-2012, 04:48 PM   #10
r0t0rhead
r0t0rhead is on a distinguished road
We've been using Electromotive TEC EFI systems & their Direct Ignition systems since early '80's (on all 3 generations of RX7's plus 3-rotor engines) with great results- cranktriggered ignition for extreme accuracy & "matched" individual coils,
http://getfuelinjected.com/products/directignition.php
r0t0rhead is offline   Reply With Quote
Old 06-17-2012, 06:32 PM   #11
justin lilley
20B
justin lilley's Avatar
justin lilley is on a distinguished road
Like This ??
http://www.dodo-logic.ca/?p=10868#more-10868 It is a Force Fed Built... 1993 Toyota 2WD ,Extra long ,wide bed . Club cab , Pickup ..with a 13B Cosmo Series 6 engine ,it has the oversized intake and Exhaust ports ( stock ) She Makes... 330 rwhp & 310ft-lbs of torque @ 16psi on Pump gas ..The power band is from 3000-7500 and totally set up for towing!..
Turbo is a a Holset HX-35 .... Transmission is ..Toyota R151 5 Speed (RWD) Manual Transmission ..... Differential is ... a one ton rear end (toyota) That is the larger 8 inch with a 4.1 Eaton LSD is true LSD. and rare 5 bolt 30 spline HD axles. .... Wheels are Supra tt 95 wheels. The offset is +50 8.5 front and 9.5 rear.
Watch Dyno run at >> http://www.youtube.com/watch?v=_jVrozzi5Uk
File Type: jpg 32 Individual sequental coil set up.jpg (143.4 KB, 26 views)
justin lilley is offline   Reply With Quote
Old 06-18-2012, 08:36 PM   #12
Wow nice picture and the discription sounds very interesting ,good job .
