Old 06-21-2010, 06:08 AM   #1
soldave
soldave's Avatar
soldave is on a distinguished road
Air pump & ACV removal: just pull & go?
Got my car through its inspection and have just installed a decat. Trying to simplify things as much as possible so am wanting to get rid of the emissions stuff, namely the ACV valve and air pump. Are they simply a case of unbolting, pulling them out, and making sure any lines are blocked off that need to be? Can't see there being much more to it but want to check.
I know I could do with another belt running up to the alternator if I do this, and am working on that
soldave is offline   Reply With Quote
Old 06-21-2010, 06:50 AM   #2
You need to block off the ACV on the LIM. It is an easy thing to do. Just get a block off plate kit.
You can also pick up a dual alternator pulley. I have one from Banzai, that I am not using anymore....
Old 06-21-2010, 06:55 AM   #3
soldave
soldave's Avatar
I've already got a block-off kit and have already blocked off the BAC.
Actually, the Japanese FC's come with the dual alternator pulley as stock, so I think I just have to get a belt for it and fit it up.
Old 06-21-2010, 07:15 PM   #4
wanganwarrior
wanganwarrior is on a distinguished road
i just removed my air pump and got a smaller belt. Bypass or block off the rubber lines going to it
wanganwarrior is offline   Reply With Quote
Old 06-22-2010, 09:47 AM   #5
LunchboxCritter
Simply Rotarded
LunchboxCritter's Avatar
You can ditch the whole rats nest. Here's how I eliminated mine, the only hard line across the top of the engine that I kept was the one going to the turbo.
LunchboxCritter
- 91 NA to J-Spec TII
- 88 FC Vert
- 04 Rx8
DO NOT TRY THIS AT HOME!!!
Old 06-22-2010, 09:54 AM   #6
soldave
soldave's Avatar
Had a look at it tonight and probably got about halfway through disconnecting the ACV from everything but then got a little lost so put it back for now. Was having trouble getting to the inner bolt connecting the ACV hard pipe to the air pump and wasn't really in a mood to play around with it. Will leave it and tackle it another day.
My intention in the end is also to remove the entire rat's nest.
