Go Back   Rotary Car Club > Classifieds > 2nd Gen Classified > 2nd Gen RX-7 Parting Out
2nd Gen RX-7 Parting Out Parting Out Mazda RX-7 You must have over 4 parts to list your items here. No new parts allowed.
Old 06-15-2010, 09:02 PM   #1
Moving sale! 2nd Gen RX-7 Parts
I have to get rid of some stuff. Make an offer, low ball me, pay for shipping, profit. Coming from zip code 24060.
If you don't see an asking price it's free. You just pay shipping and if you want you can donate above the shipping price to help me move into a new apartment (or you can dictate that any percantage you want get donated to the RCC donation box, it's your call)
Though some things I would like fair value about some stuff.
Asking $175.00 for the rear lights obo (Or you can pick up a free set here: http://www.rotarycarclub.com/rotary_...955#post120955)
Charcoal canister hard lines
Snorkle
Aluminum intake pipes (1 straight 1 90* with rolled edges)
ACV Block off plate
Clear vacuum line
Old 06-15-2010, 09:11 PM   #2
Some more stuff:
Fuse cover
Modified secondary fuel rail (no guarantee on if it holds pressure or not)
AC Pulley Wheel and Clutch
Aluminum Stock (Flat and angled)
Plastic intake piping and coupler (needs an o-ring to function properly)
(A hell of a lot more to come)
Old 06-16-2010, 08:06 PM   #3
Here's some more:
Master Clutch Cylinder (worked when pulled, more than likely will need a rebuild)--It's currently boxed
AC Coolant Temperature Sensor (it's the sensor the computer uses to make sure you're not over heating the car when you try to flip on the AC)
Weather Seal (for custom projects. It's the same type of seal used to stop drafts on doors)
Some random tool that was in my car when I bought it (I think it's original tool supplied by mazda--may not be)
20 PSI Racing radiator cap from AFCO.
More to come
Old 06-16-2010, 08:55 PM   #4
More stuff.
Inner coolant seal (only 1). I got this in a package, it was extra I'd like to see around $15 for it plus shipping, but of course it's obo. It's still new, hence why it's still in the wrapping bag it originally came from. I got this seal from Atkins (he should remember me asking him if he's ever heard anyone getting an extra seal before)
Complete door weather stripping (I believe for both doors). It's the maroon color
Rats nest with check valve and a few solenoids (still have pig tails on 'em).
Brake ducts
Air pump
Old 06-16-2010, 09:02 PM   #5
Crank Angle Sensor (CAS)
Charcoal Canister
NA FC Fuel Pump
Bag full of parts (mostly banjo bolt type stuff, and a few miscellaneous things)
Oil Pedestal
Old 06-16-2010, 09:05 PM   #6
Cruise Control Actuator
Random Brackets
Horn
Blue Clip Solenoid for Rats Nest
Emissions Pig Tails
Brand New Oil Pan Gasket
Old 06-27-2010, 09:31 PM   #7
Some more stuff (and there will be some good things later on too)
Some after market exhaust tips. They fit the stock exhaust, and to be quite honest make the end of the exhaust actually fit the car. It's amazing. Will need some work on one (grind out the old exhaust tip that I just cut off as to not damage the tip).
Brand new Mazda Trix side marker lenses (I'd like $20 for the pair, but of course obo)
Front blinker lenses (these are for the same side, I just don't know which side)
Random NPT to Barbed Hose fittings
Old spider hoses from the rats nest in fair condition... you know... for that stock look?
Old 06-27-2010, 09:33 PM   #8
Hey look: Some more stuff.
Stock shifter boot and E-Brake plastics... again, for that stock look everyone is going for.
Random bag of bolts, lug nuts, stock brake lines, and a host of other things I took off the car or replaced. (Pending sale)
Bag full of the secondary throttle plates you remove when porting and polishing the throttle body. Also includes all the hardware necessary for the system.
Random bag of nuts/bolts I think (Pending Sale)
Random nuts, bolts, NPT to -AN fittings, and a host of other stuff. (Pending Sale)
Old 06-27-2010, 10:00 PM   #9
Some S4 Turbo oil and coolant lines
Another bag of random nuts, bolts and fittings (Pending Sale)
A different bag of random nuts, bolts, and fittings (Pending Sale)
I believe that's a brand new front transmission seal... but I could be mistaken
Some S4 interior pieces
Old 06-27-2010, 10:01 PM   #10
Some S4 Power mirrors with 1 triangle piece. Asking $150 obo
End link bushing kits. Asking $30 obo
Red LED's with pig tails
Unknown computer (I think it's a power steering computer, but not sure)
Logicon black box (if your logicon isn't working, this might be the reason why)...
Old 06-27-2010, 10:51 PM   #11
Some length of possible 0 awg wire... Used to use it for a grounding wire; worked quite well.
Stock wires! For that uber JDM Stock look!
Some thick red silicon line
Ball joints (pair) asking $50 obo
Tie rods (pair) asking $40 obo
S4 TPS unknown condition
Old 06-27-2010, 10:51 PM   #12
And finally... A small bag full of washers. (Pending Sale)
Old 06-29-2010, 08:38 AM   #13
Seriously guys, post what you want; you have pretty much two weeks before I start throwing stuff out.
Old 06-29-2010, 09:13 AM   #14
I'd be all about bags of nuts and bolts. God knows I've probably left numerous ones off my car or lost them. How much shipped to 37013?
Please PM a reply as it send me an email.
Old 06-29-2010, 10:03 AM   #15
PM Sent!
cheap, emissions, suspension, tail lights
