Old 06-13-2010, 03:02 AM   #1
Mazdabater
FC3S
My electrical gremlin.
So recently I pulled out my dash to re seal the ac ducting and re route some wires off my suspension controller. All went well until it came to reinstalling my stereo and suspension controller.
Now I know I should have tested this with a multi meter but I didn't have one at the time. Confirmed 12v+ by earthing it out and soldered the wires in. Joined the earth up that I had installed whilst the dash was out. Then came the acc wire. I earthed it out, nothing. Turned key to acc and it earthed out. Cool soldered it up. Replaced the radio fuse and the room fuse. No good. I can hardwire the radio and suspension controller to the 12v+ and turn it on and off manually but I don't want that.
So wtf could have happened. All fuses seem good? On a side note after this my power windows have stopped. Have yet to pull the door trims and see whats going on there, I'm unsure if it is related. I think the switch may have just died as its getting 12V at the fusebox.
Hoping to get an idea before I have to mess around running an acc wire off the ignition pigtail, something has to have failed.
