Old 05-30-2010, 01:49 AM   #1
any oem D shaft tps sensors?
im pretty sure my haltech tps is screwed. With the accel enrichment table up on the MS and even without the engine running, i see readings from 9 %/s to even 200 or more %/s without touching the pedal.
Its causing a lot of low speed bucking and poor running due to the acceleration enrichment activating.
so in lieu of spending 100 dollars on another haltech tps, is there something i can get from a junkyard? I really dont have to modify my throttle body shaft to accept something like a blade type GM sensor.
