Old 05-21-2010, 12:36 AM   #1
Grappler
Grappler is on a distinguished road
Jumper for Fuel pump
I need to prime my fuel system soon and I can't find out what plug I need to Jumper.
I know its near the Passenger shock tower and its either green or yellow....
could anyone post a picture or a description of the plug.
Thanks
Grappler is offline   Reply With Quote
Old 05-21-2010, 12:43 AM   #2
Howru
Louvers!
Howru is on a distinguished road
Yellow 2-pin connector, or you can hold the AFM flap open.
88 GXL N/A -- Maybe I should've kept the exhaust diffusers...
Howru is offline   Reply With Quote
Old 05-21-2010, 08:00 AM   #3
+1 and if IIRC it's on the bumper side of the shock tower.
Old 05-22-2010, 06:03 AM   #4
N.RotaryTech
Home-brew Rotary
N.RotaryTech's Avatar
Passenger side shock tower.
'87 RX7 GXL, Rest In Pieces.
'94 Ford Ranger, daily.
Old 05-28-2010, 08:16 PM   #5
madscientist
madscientist is on a distinguished road
Passenger side shock tower is where you will find it. You can't miss it, because it's the only connector in that area that will be loose(nothing connected). All you have to do is put a jumper wire on it to connect the 2 pins and then turn the key to "ON" while your battery is connected then you're good to go.
madscientist is offline   Reply With Quote
