Old 03-22-2008, 02:18 PM   #1
banzaitoyota
banzaitoyota is on a distinguished road
Nikki wont stay running
12A RX2 unknown mods to car. It will start and idle if I prime the carb. I have good fuewl pressure to the carb. Where do I start?
My deuce
banzaitoyota is offline   Reply With Quote
Old 03-22-2008, 03:18 PM   #2
banzaitoyota
here is the problem child
My deuce
Old 03-22-2008, 06:28 PM   #3
Sterling
Premium Vendor
Sterling is on a distinguished road
Beautiful carb. Same one I have on my Rx-7.
By "priming" I'm assuming you're opening her up and filling the bowls manually.
The first rule in carb troubleshooting is "Follow the Fuel".
Start with the pump. Is it running? Check the fuse. It should kick on for a second when ignition is first engaged, though I'm not first-hand familiar with pre Rx-7 models.
Next up is the filter. I suggest that the filter would rarely be the culprit in a case like this because if the pump is working then you have an actual obstruction in route from the tank to the carb. But if you have large flecks of crap in the filter from inside the tank, it can help in your diagnosis.
Be sure the tank is breathing properly. When a tank becomes vapor-locked the whole fuel system gets screwed up. If you remove the cap and the tank "whooshes" excessively, there's a problem somewhere.
Blow through the return line to the tank by mouth to be sure it's not obstructed.
Last edited by Sterling; 03-22-2008 at 06:29 PM. Reason: BTW, I'm gonna move this to the "Carburetors and Carb Tuning" section.
Sterling is offline   Reply With Quote
Old 03-22-2008, 07:24 PM   #4
banzaitoyota
Here is a graphic of what I have found. I blew thru the return line it is clear
My deuce
Old 03-22-2008, 07:43 PM   #5
banzaitoyota
More Info:
Car has a Fuel cell, Facet Pump / standard inline filter
Need to check pressure in the AM.
My deuce
Old 03-22-2008, 08:19 PM   #6
banzaitoyota
found one problem, Previous owner had fuel lines run backwards
and the unknown connection is the choke shaft tube
My deuce
Old 03-22-2008, 08:20 PM   #7
Sterling
Premium Vendor
The part circled in the diagram is where the linkage for the choke rod goes. It's not a port.
-ya beat me.
Old 03-22-2008, 08:23 PM   #8
banzaitoyota
I'll put a fuel pressure gage on it in the morning
My deuce
Old 03-22-2008, 08:28 PM   #9
Sterling
Premium Vendor
I'll check in mid morning Eastern time.
Old 03-23-2008, 07:14 PM   #10
banzaitoyota
It runs!!!!! Now to fix the brakes
My deuce
