Old 04-30-2010, 11:10 PM   #1
TS87FC3S
Ask Me About My WANKEL!!!
TS87FC3S's Avatar
TS87FC3S is on a distinguished road
Booster Issue
so heres my issue my idle seems fine now except when i hit the brakes it drops lightly if i pump the brakes the car tries to die, is there any weird way of testing booster.. i tried pulling vaccum (vaccum pump) and it wouldnt even build 1 in/hg. But i cant hear where its leaking and brakes feel great.
1984 Rx7 Gs - stripped interior re speed coil overs, tokico blues, re speed crossmemeber and mustang rack, diamond star racing wheels
1988 Rx7 Se - Sold
1988 Rx7 GXL - Sold
TS87FC3S is offline   Reply With Quote
Old 05-01-2010, 11:15 AM   #2
Kentetsu
Kentetsu's Avatar
Sounds like a blown diaphragm in the booster, but before jumping to that conclusion I would take a good look at the check valve in the vacuum line.
Old 05-01-2010, 02:47 PM   #3
TS87FC3S
TS87FC3S's Avatar
i replaced the rusted metal line with a rubber line so i dont have the check valve, i dont think.
1988 Rx7 Se - Sold
1988 Rx7 GXL - Sold
Old 05-03-2010, 09:05 AM   #4
Kentetsu
Kentetsu's Avatar
The check valve should be inline in the rubber hose (at least on 1st gens). If you don't have a check valve, then whenever you go above idle and lose manifold vacuum your booster will also lose it's vacuum.
Old 05-03-2010, 11:34 AM   #5
....and you can also damage the diaphragm under boost, or so I've been told.
