Old 04-29-2010, 04:06 PM   #1
Garfinkles Motor Works
Remove the omp and block the hole
For the cars using premix and needing to remove the oil metering pump I have made a 3/16 steel plate to cover the oil hole . The steel is thick enough to hold the gasket and not flex. The plate is very slightly larger than the metering pump so the area around the bolt holes is stronger .The gasket material is rubberized and the bolts and washers are stainless steel .The price is $18 plus shipping .If you need one they will be available through this forum only and as with all my products and work you will be satisfied with thefit and function.
Old 04-29-2010, 04:29 PM   #2
proz07
Needing a new tow rig.
proz07's Avatar
what about blocking the injector ports?
z
Old 04-29-2010, 05:08 PM   #3
I put in flange bolts with the stock copper crush washer to seal the holes .Should I supply the bolts and up the price ?
Old 04-29-2010, 10:01 PM   #4
proz07
proz07's Avatar
i think it would be a more complete kit. being the plate only covers half the system and most people have a hard time finding the CORRECT thread pitch to block the injectors. im sure there are a lot that wouldnt know the difference but for those of us that want to do it right... or even as an option i guess for the cheap guys that dont want em. personally i was gonna weld up the hole after removing the shaft and gear and internal oiling hole but then again i dont want to pull the front cover just for that either so ill get the plate for now or well soon.
O and i love the engine brace ill get ahold of you for that later
z
Old 04-30-2010, 07:21 AM   #5
I will check on the bolts today .
Old 04-30-2010, 04:49 PM   #6
Force13b
cxxxx|::::::::::::>
Force13b's Avatar
The kit i used came with nice flush fitting allen set screws
Old 04-30-2010, 05:59 PM   #7
proz07
proz07's Avatar
and that would be the banzia-racing kit. not bad at 20$ which is the one i was gonna get or at least just the allens if i were to weld my cover first but motors in now and im not cracking it just for that ill use the plate. but if Garfinkle makes the COMPLETE kit with injector blocker bolts this is the only other comany offering this correct style so far. from what i understand all others just use an NPT threaded insert/bolt which has the 'possibility' or deforming the housing if torqued too much. personally i find that statment BS cause ost will have problems with the spark plug hole deforming/cracking long before the oil injector block will give any issues.
But as stated earlier i kinda want to do it right with the right bolt thread pitch for reversibility if needed and for a few cents its worth it.
z
Old 04-30-2010, 10:56 PM   #8
I have located the flange style bolts so I may order some Monday . They may have crush washers as well .
Old 05-01-2010, 07:50 AM   #9
C. Ludwig
Rotary Masochist
S5 will use the same plate. Expand you market.
http://www.lms-efi.com
chris@lms-efi.com
502-515-7482
Facebook @LMS-EFI
Old 05-01-2010, 08:25 AM   #10
Good point,and thank you.I will post in the sec gen section and in my venders section when I get the bolts.
Old 05-05-2010, 08:36 PM   #11
I have the bolts cut and the washers ready I will repost with pictures tomorrow .
