Old 03-22-2008, 11:13 AM   #1
McVicker
McVicker's Avatar
McVicker is on a distinguished road
An easier way to drain your oil?
I know it's not that hard to begin with, but it sucks when you drop the oil drain plug into the oil pan. I found this oil drain adapter made by fumoto, looks like it will make draining the oil a breeze. I'm gonna grab one of these in the next few weeks and post some pictures with it installed.
Check it out....
Fumoto valve
Scrubs McBubs!
SakeBomb garage.com
McVicker is offline   Reply With Quote
Old 03-22-2008, 11:46 AM   #2
dhays
dhays is on a distinguished road
I've wondered about these so I'd be glad to hear how they work for you. I've been using the same type of oil extraction that I use on my boat. It works really well and I'm able to get the same amount of oil out of the car without ever having to get underneath it.
Dave
dhays is offline   Reply With Quote
Old 03-22-2008, 01:55 PM   #3
a7xh7
a7xh7 is on a distinguished road
yeah i regret buying the fram type one everytime i see this one posted
"sevens_ix"
a7xh7 is offline   Reply With Quote
Old 03-22-2008, 03:05 PM   #4
BLKTOPTRVL
BLKTOPTRVL's Avatar
They seem to extend very far out of the car; especially the type with the nipple on it.
I would be concerned about going over speed bumps, street garbage, etc.
I would be curious to know (once you get it installed) just how far it does extend.
Old 03-22-2008, 04:20 PM   #5
McVicker
McVicker's Avatar
If you're sub-frame is hitting the ground going over speed bumps then you have problems already
Scrubs McBubs!
SakeBomb garage.com
Old 03-22-2008, 08:39 PM   #6
a7xh7
cant hit that part of the car going over speedbumps. the underbody Behind the wheels is what gets hit, when u roll OFF the bumps. after looking at the pictures i do'nt think even the one with the nipple will be a problem, my fd is super low in front and the fram unit sticks out almost as far, maybe 2-3mm shorter but i don't worry about it catching any pavement
"sevens_ix"
Old 03-23-2008, 12:13 PM   #7
CLH
CLH's Avatar
CLH is on a distinguished road
I've run Fumotos on every car I've owned in the past 8-10 years or so - everything from F150s and Exporers to Miatas and RX7s - and have never had an issue. I can't count how many conversations I've seen about the Fumoto valve on car boards over the years (and someone *always* claims that they're dangerous 'cuz they'll get 'broken off over a bump'), but not once have I seen a post about someone actually experiencing a failure.
The Fumoto on my FC doesn't extend anywhere near far enough to catch on anything that I might run over.
CLH is offline   Reply With Quote
Old 03-25-2008, 08:08 PM   #8
Turbo10th
Turbo10th's Avatar
Turbo10th is on a distinguished road
Or you can make it easier by not even having to get under the car by geting on of those things that suck the oil out of the oil filler or dip stick it is like $80though.
1993 Mazda Rx-7 VR R1 (11/06/07)
1991 Mazda Rx-7 Vert (SOLD 10/31/07)
1988 Mazda Rx-7 Turbo 2 (03/25/07)
1988 Mazda Rx-7 10th AE Project
1988 Mazda Rx-7 GXL (SOLD 03/14/07)
Turbo10th is offline   Reply With Quote
Old 03-25-2008, 08:28 PM   #9
Signal 2
Viable Fossil
Signal 2's Avatar
Nice piece I'm sure. But I never thought removing the OEM drain plug was all that big of a hassle.
Jim
VR R1 FD
Old 03-25-2008, 09:07 PM   #10
McVicker
McVicker's Avatar
It's not, but replacing the crush washer is annoying...and how much easier can that valve be, no tools required. I would rather get under my car to change the oil, maybe I'm old fashioned .
Scrubs McBubs!
SakeBomb garage.com
Old 03-25-2008, 09:51 PM   #11
RXtacy
RXtacy's Avatar
I'm sure having a lift doesn't influence your willingness to get "under" the car at all.
93 Frozen Grey Metallic FD
Build thread here
17 Camaro SS 1LE
04 RX-8 GT
but I'm getting old
Old 03-26-2008, 08:58 AM   #12
Signal 2
Viable Fossil
Signal 2's Avatar
I've owned my FD for several years now and never have had to replace the washer. It's never leaked either.
NOT having to get under the car (on put it on the lift) would be nice sometimes. But I'm definitely old fashion....using the occasion of a oil change to check the entire underside of the car can pay dividends too. How many of us have discovered something else leaking, broken, worn-out or out of place during an oil change and were able to take care of it before major issues began?
That said, I've never seen this particular model....which seems better quality than the others and I might get one eventually. Just not high on the priority list.
Jim
VR R1 FD
Old 03-26-2008, 01:28 PM   #13
albertomg
Ray Crowe packs a crush washer with every oil filter he sends me. Good guy that Mr. Crowe. Never had a problem with the good ole fashioned way.
To each their own of course.
Old 03-26-2008, 01:35 PM   #14
bop_rocco
bop_rocco's Avatar
bop_rocco is on a distinguished road
link off this forum
http://www.rotarycarclub.com/showthread.php?t=12&page=2
i got mine from here, just get the 6000 it works well for me i have used it on the 7 and a blazer ( since oil filter is near the front).
http://www.jerrybleach.com/pelapumps.html
PwrFC, Twins @ 14lbs, 1300 sec w/supra pump,
smic w/ pettit intake, M2 cf intake, 3in downp-mid w/ Carbon Ti,
mazda perf radiator, dvd/tv, mazdaspeed cf lip and cf feed sides, SSR sp1's 18-9's and 10's - 255-275
re-a diffuser, and 99front and wing soon.
bop_rocco is offline   Reply With Quote
Old 03-26-2008, 06:04 PM   #15
Who replaces the crush washer?
