Old 03-31-2010, 08:31 AM   #1
hecmanortiz
hecmanortiz is on a distinguished road
Compression Tester
What are the differences between piston and rotary compression testers? I have a buddy who has a piston compression tester and this is something I wouldn't use frequently so why spend the money on one for use maybe twice.
Tks.
hecmanortiz is offline   Reply With Quote
Old 03-31-2010, 10:57 AM   #2
PercentSevenC
Custom User Title
PercentSevenC's Avatar
A piston engine compression tester only shows the peak compression for one chamber. To measure rotary compression, you either need to use a rotary tester, which records all three pulses, or remove the valve thing from a piston engine tester so you can at least watch the needle and estimate all three pulses.
Old 04-01-2010, 05:02 PM   #3
hecmanortiz
Great thanks.
