Old 03-30-2010, 12:19 PM   #1
LunchboxCritter
Simply Rotarded
LunchboxCritter's Avatar
J-Spec TII Vacuum Reroute
Will this set up work for me? I am putting a J-spec TII S5 into my S5 NA car. I have removed the ACV, Split Air, Air Pump (installed dual pulleys on the alt), and have installed block off plates, I am planning on keeping the BAC as I'm keeping A/C. I am unsure how the oil catch should be hooked up, could someone confirm setup? Also can the stock pressure sensor be blocked off or does it need to be routed to the manifold?
