Old 03-21-2010, 08:32 PM   #1
Dobbs
Dobbs is on a distinguished road
RX-8 will not turn over, no power-steering...
My rx8 isn't running the last time it was the power steering went out and when I turned it off it wouldn't turn over again even with a jump it tries but nothing any ideas would be welcome.
Last edited by Phoenix7; 05-28-2010 at 03:08 PM. Reason: edited thread title to reflect content
Dobbs is offline   Reply With Quote
Old 03-22-2010, 01:24 AM   #2
ZGN
Administrator
ZGN's Avatar
What do you mean it tries? Does the engine turn over or do you just hear a click?
Kevin
Old 03-22-2010, 11:04 AM   #3
Have you tried to de-flood it?
Pull out your spark plugs
Disconnect the Eccentric Position Sensor (down pointing at the crank pulley, driver side)
Crank it for like 10 seconds
Put plugs back in (if they are good)
Try to start it.
You might also have a bad coil, or coils. And depending on the year, you might have the 'bad' starter.
We need more info. Modifications, mileage, year model.
Old 03-22-2010, 12:51 PM   #4
reddozen
Gold Wheels FTW
reddozen's Avatar
Try to start it.
There's 2 ways of doing it.
If you're stuck somewhere and cant get out the plugs, pull the fuel pump fuse and crank it several times and this will vent it into the exhaust, then replace the fuse and see if it will start. I've done this a couple times when I'm in a bind, and don't have time to mess with it.
Other wise pull the plugs, brake clean and wire brush them, pull the fuel and fuel pump fuses and blow the gas out the plug holes. Then just replace the plugs and fire it up. If it floods again while trying to crank it i usually resort to the previous method rather than pulling the plugs again.
I've never head of disconnecting the EPS DJ, but that doesn't mean that it may not be worth wild.
My Cars:
1974 RX4 Coupe
1991 FC3S RX7 - Sold
Old 03-22-2010, 01:51 PM   #5
Unplugging the EPS disables both fuel and spark
Old 03-22-2010, 02:25 PM   #6
reddozen
Gold Wheels FTW
reddozen's Avatar
good to know. i'll have to remember that one.
My Cars:
1974 RX4 Coupe
Old 03-22-2010, 06:39 PM   #7
mazda master tech
Gear Head
mazda master tech's Avatar
mazda master tech is on a distinguished road
There is 2relays !start relay 2 is the EPS relay. Check for 12v & grd .Also Eps fuse at + terminal,and ground under battery .Good Luck.
mazda master tech is offline   Reply With Quote
Old 03-22-2010, 10:52 PM   #8
Rotary Inspired
Rotary Inspired is on a distinguished road
or you can go the easy way.
Remove the vacume box like thing behind the MAF held on w/ a worm clamp. Spray carb cleaner in there. Replace the vacume box back. Pull fuel pump fuse. Go start the car. It will start. After it starts jump out and place the fuel pump fuse back in. She will stay running.
After i fouled the plugs once and had to remove the stupid front tire to get to them i said screw that. I found an easier way. Works like a charm.
Make sure the car is in nuetral when you start it so you can jump out. or get the assistance of a friend.
If you wanna become ASE certified buy the RX7.
Rotary Inspired is offline   Reply With Quote
Old 03-22-2010, 11:38 PM   #9
Why not roll start it?
Old 03-23-2010, 05:21 PM   #10
Dobbs
Thanks everyone I'll start trouble shooting.
