Old 03-19-2010, 08:42 PM   #1
TS87FC3S
Ask Me About My WANKEL!!!
TS87FC3S's Avatar
TS87FC3S is on a distinguished road
Exclamation Bucking under load?? Need help asap please
88 gxl, random miss at idle but revs out fine with no load on engine. but once in gear going down the road the car bucks ALOT! what can cause this?
Fuel Filter New, Decent Plugs.
This started happening after a 7k 1-2, 7k 2-3 then decel, this is when it first started occuring??
Im in illinois with the car need to get it back to missouri tomorrow!!
1984 Rx7 Gs - stripped interior re speed coil overs, tokico blues, re speed crossmemeber and mustang rack, diamond star racing wheels
1988 Rx7 Se - Sold
1988 Rx7 GXL - Sold
TS87FC3S is offline   Reply With Quote
Old 03-19-2010, 10:30 PM   #2
Kentetsu
Kentetsu's Avatar
I was going to ask about spark plugs, but I guess you've got that covered. Any charging issues, like maybe the alternator going out on you? Or bad grounding of the motor maybe.
Other than that, I guess you'll have to look at fuel delivery issues, and I'm a carb guy so I'll wish you good luck.
Old 03-20-2010, 12:05 AM   #3
Tps?
Old 03-20-2010, 09:04 AM   #4
TS87FC3S
TS87FC3S's Avatar
Actually I Am having charging issues the parts stores tell me the alternator is good but on the car it is only putting out like 12.6v new battery, it also when I go to start it it just clicks even though battery has full voltage it has to be jumped... I'm gonna recheck plugs and try to find specs to check gps and other sensors, and check fuel system
Anything else I should check
1988 Rx7 Se - Sold
1988 Rx7 GXL - Sold
Old 03-22-2010, 11:15 AM   #5
Kentetsu
Kentetsu's Avatar
Battery cables and connections at both ends. lol, who says carb guys don't know crap?
Old 03-29-2010, 07:29 PM   #6
TS87FC3S
TS87FC3S's Avatar
Dropped the fuel tank and cleaned it, changed the filter, cleaned plugs and added engine and body grounds car runs perfect now.. Good enough to get a good sized speeding ticket
1988 Rx7 Se - Sold
1988 Rx7 GXL - Sold
