Old 03-16-2010, 10:48 AM   #1
bigzman
bigzman is on a distinguished road
Drivers Side Door Handle
I have taken out the cylinder on the spare. Is there a trick to take the handle out of my 91 other that 1 bolt off with window down and the other up.
Any input would be appreciated as to any shortcuts to speed up the process. I am replacing it on Wed. I am a weekend mechanic
Thank You in Advance
bigzman is offline   Reply With Quote
Old 03-16-2010, 01:13 PM   #2
classicauto
crash auto?fix auto
classicauto's Avatar
Only things holding it in are the two nuts, and the rods for the latch and lock cyl.
A tip would be making damn sure you open the clip on the handle for the latch rod properly. Use a small pick and open the "door" on it. Seen a few of them broken by "pros" lol
Make sure as well to take any slack out of the rods when you put the above clip back on. You'll notice the design allows some adjustment, just make sure its not super loose when you clip the clip back together.
Old 03-17-2010, 06:28 AM   #3
bigzman
TY for the that info. Will do as you suggest.
