Old 03-08-2010, 02:29 PM   #1
ParadoxZero
ParadoxZero is on a distinguished road
Awd?
hey guys, i'm new to the forum, well first post, but i've been reading for a while. has anyone ever thought of, or put together an AWD rotary car? anyone wanna talk about the possibilities?
ParadoxZero is offline   Reply With Quote
Old 03-08-2010, 04:07 PM   #2
There were AWD RX-7's in first gen and second gen form used for Pikes Peak Rally. If you do a google search you can find some interesting pics. The whole drivetrain was custom.
The easiest option to do something more modern would be to rotary a Subaru. There is a group of guys called 'Rust in the Wind' that have just completed a Subaru Brat with a rotary engine and trans, it also has a Miata front subframe and suspension.
So yes, it can be done, is it cheap and easy, not really!
Old 03-09-2010, 08:43 PM   #3
Rod Millen...
Funky 626 front transaxle set-up
Old 04-12-2011, 10:30 PM   #4
just an interlude into this, i have no idea what the front differential they used is. i really dont. i cant find anything like it in the aftermarket
Old 05-10-2011, 04:48 PM   #5
j9fd3s
i recall, that the front diff was for an alfa romeo or something weird...
i was going to say though, 626 strut/brakes almost bolt into an FC, axles arent too bad, if you were cheap, you can run a B2600 4x4 trans and transfer case (its a T2 trans with the transfer case added).
but the front diff is a problem! not only do you have to find one, it's gotta fit too!
millen moved the engine, back and to the side, which in a "street" car isn't getting very practical.
i looked into this a couple months ago, it turns out the FC has the same ball joint design as the FWD cars, its not a tapered seat like all the mazda RWD cars. i was hoping to use maybe a miata upper arm, and i dunno FD spindle, and have easy double wishbone, but no....
