Old 03-07-2010, 12:58 AM   #1
need RX7
Clean S4 Nutswinger
need RX7's Avatar
Question about RA OMP adapter and S5 OMP
So, I've pretty much decided that I'll be running an S5 engine in my car in the future, and I'd like to run an S5 omp with a Rotary Aviation OMP adapter so I can inject 2-stroke oil instead of dirty sump oil, and also not have to deal with the throttle linkage of the S4 omp. *I plan on having a Haltech Platinum Sport 1000 by then, which does support an electronic OMP.
I've noticed in Rotary Aviation's OMP adapter listing that they don't offer one for an electronic 2nd gen OMP, only mechanical 2nd gen pumps and electronic 3rd gen pumps.
However, I also noticed that Pineapple Racing lists their OMP block-off plate as fitting both 2nd gen and 3rd gen electronic pumps, which means they must have the same bolt pattern.
So, my main question is; Could I use RA's 3rd gen electronic OMP adapter with a series 5 OMP and front cover? Their bolt pattern appears to be the same, but I suppose there could be a difference between the driveshaft(?) locations, or perhaps something else I don't know about?
