Old 03-01-2010, 03:01 PM   #1
Proxy One
Victory Is Mine
Proxy One's Avatar
Proxy One is on a distinguished road
Synapse Wastegate vacuum diagram
I am in the process of installing a single turbo kit on my car and am using the 50mm Synapse wastegate and am just curious if anyone could tell me where to hook the hoses up at ?
Thanks
Jeremy
www.dealsgaprotaryrally.com
1994 Rx7 White 2001 RZ GT35R'd
1972 Rx2 Orange Coupe 5spd
2006 STi
1986 Buick GN
Proxy One is offline   Reply With Quote
Old 03-01-2010, 11:10 PM   #2
RotaryProphet
http://www.synapseengineering.com/pdf/wg-manual.pdf
There's the manual; it'll give you the chart to show you which spring to use, and what ports to hook up to get certain boost levels.
On a side note, I -love- the synapse wastegates, and I'll never use a different one again. It took my peak power up 16 horsepower, and raised the average torque by 30 ft/lbs. It's a fantastic piece.
Old 03-02-2010, 12:01 AM   #3
rotor85
rotor85's Avatar
rotor85 is on a distinguished road
I gotta agree...synapse wg has been the best i have used. I had some boost irregularities with my old hks 40mm but once i put the 50mm synapse on, the creep and fluctuation went away. i got mine set at 11psi and it holds dead steady as low boost and i can alter it with my EBC to go to 20psi.
rotor85 is offline   Reply With Quote
Old 03-16-2010, 11:27 AM   #4
Proxy One
Victory Is Mine
Proxy One's Avatar
So you use a boost controller with the Synapse WG? How do you run the hoses for this? Im thinking of just starting with the C vacuum hose hooked up for simplicity.
2006 STi
1986 Buick GN
Old 03-16-2010, 03:31 PM   #5
RotaryProphet
No, you don't need a boost controller unless you want to change the boost level from the cab. Just hook up the ports according to which boost level you would like, and to change the level, move the hoses.
Old 03-16-2010, 06:51 PM   #6
Mobius
Rotorhead
^^ What he said, or unless you want a higher boost level than what is available (the highest I can go without a boost controller is 17psi.)
Also note that the boost level they claim may not be what you actually get, it takes a little trial and error sometimes, with different spring/port combinations. I think they have a disclaimer stating this as well.
