Old 02-28-2010, 02:47 PM   #1
rotaryguy481
rotaryguy481 is on a distinguished road
Electric Fan
What kind of electric fan works good on a FC n/a
rotaryguy481 is offline   Reply With Quote
Old 02-28-2010, 04:46 PM   #2
All different kinds. Shook Racing makes a sweet set up with an aluminum shroud. Spal makes great fans. Stay away from the auto parts cheapies.
Alot of FC guys will use a Ford Taurus or Escort e-fan. They fit the radiator great, and draw a small amount of amps.
Old 02-28-2010, 04:59 PM   #3
rotaryguy481
sweet thanks alot bro didn't know what to do lol
Old 02-28-2010, 05:00 PM   #4
http://www.aaroncake.net/rx-7/efaninstall.htm
Old 02-28-2010, 07:01 PM   #5
88turboii
destroy, rebuild, repeat
88turboii's Avatar
i run the single-speed taurus fan, havent had any problems with it
Old 02-28-2010, 07:21 PM   #6
Dazed and Rotarded
douche bag
Dazed and Rotarded's Avatar
Dazed and Rotarded is on a distinguished road
You can use a dual from a audi with alittle trim.. The taurus work's great also like mentioned.
- chris
xbox live - GraveConditions
R.I.P paul gray - # 2
Dazed and Rotarded is offline   Reply With Quote
Old 03-01-2010, 02:32 AM   #7
The best fan for an N/A RX7 is the one that the factory fitted on there. I see toooooooo many efans installed incorrectly and they do more harm than good.
Old 03-01-2010, 03:35 AM   #8
TS87FC3S
Ask Me About My WANKEL!!!
TS87FC3S's Avatar
TS87FC3S is on a distinguished road
True but an efan helps clean up the engine bay, and used properly works as good if not better then stock.. Just stray away from cheepies either use a good fitting stock one off another car of spend the money for a good low amp efan
1984 Rx7 Gs - stripped interior re speed coil overs, tokico blues, re speed crossmemeber and mustang rack, diamond star racing wheels
1988 Rx7 Se - Sold
1988 Rx7 GXL - Sold
TS87FC3S is offline   Reply With Quote
Old 03-01-2010, 11:54 AM   #9
infernosg
IT'S ALIVE!
infernosg's Avatar
Try to find a good (high flow rate, low amp draw) 15-16" puller, pick up a SPAL (or other) programmable thermoswitch and custom make a fan shroud out of aluminum, fiberglass, etc. to fit to fit over your radiator. That should be the makings of a good e-fan setup...
Old 03-01-2010, 03:05 PM   #10
Polito Racing
so you got pistons oh wow
Polito Racing's Avatar
Polito Racing is on a distinguished road
Im running the later model mercury cougar fans setup in my car and works great. its a double fan setup and the shroud fitted prefectly on my radiator. It looks very clean.
Polito Racing
2000 F-350 SD (Daily Driver)
2002 CBR 954RR (Back on the Road)
1987 RX-7 Turbo II(red bullet!!)
Polito Racing is offline   Reply With Quote
Old 03-03-2010, 11:19 PM   #11
knonfs
knonfs is on a distinguished road
Flex a lite black magic fan, used for over decade back home (90F avg temps), and never had a problem.
knonfs is offline   Reply With Quote
