Old 02-22-2010, 07:03 PM   #1
sen2two
KTEC
sen2two's Avatar
rebuilding a motor, something strange?
I noticed there was slight scar on the rotor housing near the exhaust port. but there was nothing broken in the motor. So as i inspected the rotors, they looked fine also. until i checked the apex seal slot. the tops of them have burrs on almost every edge. I know this isnt normal, cause i havnt noticed this before in other builds i have done.
so would filing the burr off ever so slighty be ok?
what might have caused this?
what I have:
What I had:
Old 02-24-2010, 07:13 AM   #2
Scars on the rotor housing could be from a chunk of carbon flying around.
Burrs on the apex seal groove?
Some rotors come with machined rotor faces - you'll notice the lines.
This causes the jagged edges on the apex seal grooves...if this is what you're talking about?
Old 02-24-2010, 11:29 AM   #3
sen2two
KTEC
sen2two's Avatar
just to be a little more clear. this is what i mean by burrs on the apex seal slot. The red indicates where the burrs are. They are exagerated a little in the picture i drew.
and yes, these rotors have the lines, so they might be the machined ones. If this is indeed the case. filing the burr off a bad idea?
(im not artist)
what I have:
What I had:
