Go Back   Rotary Car Club > All thing Racing! > Racing tech for Drag
Racing tech for Drag All tech stuff relating to Drag racing... Please, Don't talk about street racing.. It will be pulled and multiple offender will be BANNED!
Old 03-20-2008, 04:12 AM   #1
AndreS
AndreS is on a distinguished road
front wheels/tires- will these fit?
I found an OK deal on some centerline wheels, I just don't know if they will fit /o rubbing the fender.
wheels are 15x4 with 1.625" backspace (i think that's -22mm offset) and I already have 25x4.5-15 M/T front runners.... but my question is: will they rub the fenders?
I'm OK with them sticking out a little, but not OK with them rubbing, for obvious reasons.
AndreS is offline   Reply With Quote
Old 03-20-2008, 10:09 AM   #2
P71
P71's Avatar
A 225/40/18 will fit with no rubbing which is 25.1" tall, so height shouldn't be an issue. Shoot a PM to Josh (he's on the Top 25 list with the LS1 FC in OR) as he has a 245 or 255 up front with rolled fenders, so he might know more as far as the back-spacing or height right at the lip.
http://www.miata.net/garage/tirecalc.html
Michael Pinto
Read my Rx-7 Build Thread!
Vote for the ROTM!
P71 is offline   Reply With Quote
Old 03-20-2008, 02:19 PM   #3
josh18_2k
according to an offset calculator, the outside of a 4" wheel with -22 offset sits almost the same as a mustang gt wheel (8", +30). so that sounds like a good fit.
unfortunately offset is not directly derivable from backspacing, since the 4" doesnt include the lip of the rim.
do you have stock suspension in front? if so, its a really close call (how far will it compress on the brakes?)
Old 03-20-2008, 10:57 PM   #4
busted7
busted7 is on a distinguished road
The only skinnies i got to fit right is bogart 3.5'' with 3'' back space 15'' drag on flystar special order 4 lug. I also run the na brakes to clear the wheels.
busted7 is offline   Reply With Quote
Old 03-21-2008, 03:56 AM   #5
AndreS
I've seen one FC running 2.25" BS and it looked great.
For suspension I have stock springs up front with KYB adjustable shocks. I'll likely be running the shocks set to full soft up front at the track.
I forgot to mention that I'll be running the NA brakes for clearance as well.
I think I'll pass on these for now & look for a little more backspace.
Old 03-21-2008, 09:03 AM   #6
busted7
Yha i tried the prostars with 1.75 bs and they hit the fenders so i had Rich Bogart make the wheels for me. Im running 12x15 Bogarts on the back with 29.5 10.5 w's slicks on the back with ford 9''. I need to finish this thing!!
