Go Back   Rotary Car Club > Vendors and Group Buys > All Vendors > FDNewbie Imports
FDNewbie Imports Import Rare Japanese Only Parts to USA.
Old 03-19-2008, 06:53 PM   #1
McVicker
McVicker's Avatar
McVicker is on a distinguished road
Fun with oil cooler & Vmount ducting!
Charlie (cabaynes) and I decided to make up some ducting for my VMount and Oil Cooler kit... here are the results (don't mind the scribbled movie quotes on the top)
Scrubs McBubs!
SakeBomb garage.com
McVicker is offline   Reply With Quote
Old 03-19-2008, 11:03 PM   #2
MaczPayne
Bah!
MaczPayne's Avatar
Is the main duct offset or is it just my eyes?
Johnson
TA FC in the works!
Old 03-20-2008, 12:34 AM   #3
McVicker
McVicker's Avatar
The rotary extreme radiator is offset to the passenger side. Our radiator will be mounted in a similar fashion. The radiator has to be set to the passenger side to allow clearance for the A/C lines. If you look at the frame rail above the ducting you can see that the radiator is offset.
Scrubs McBubs!
SakeBomb garage.com
Old 03-20-2008, 08:10 AM   #4
RXtacy
RXtacy's Avatar
Looks great Dan
93 Frozen Grey Metallic FD
Build thread here
17 Camaro SS 1LE
04 RX-8 GT
but I'm getting old
Old 03-20-2008, 02:45 PM   #5
McVicker
McVicker's Avatar
Thanks....hopefully tonight we'll get started on the undertray/lip spoiler. You can see the huge piece of blue alumacorr in the background.
Scrubs McBubs!
SakeBomb garage.com
Old 03-22-2008, 04:07 PM   #6
McVicker
McVicker's Avatar
and the finished product....yes I know the car is dirty as hell.
Scrubs McBubs!
SakeBomb garage.com
Old 03-23-2008, 12:03 PM   #7
blwnrtr93
blwnrtr93's Avatar
I like that ductwork. Functional and aesthetically pleasing.
1993 BB RX-7
2005 Black Mazda 6i
1991 Primer Celica GT
1968 Camo Chevy P/U
Old 03-25-2008, 12:22 AM   #8
Lotte
~Flippy~
Lotte's Avatar
Lotte is on a distinguished road
looks great
Lotte is offline   Reply With Quote
Old 03-25-2008, 10:09 PM   #9
Prometheus
Prometheus's Avatar
Prometheus is on a distinguished road
What is the price of the V-mount kit?
Prometheus is offline   Reply With Quote
Old 03-26-2008, 07:24 AM   #10
McVicker
McVicker's Avatar
That is actually the Rotary Extreme v-mount not ours, ours will not have the drain hole on the wrong side . We are working on the A/C portion of our kit right now.
Scrubs McBubs!
SakeBomb garage.com
Old 10-13-2008, 08:03 PM   #11
hsitko
hsitko is on a distinguished road
First off, i'm really not trying to be lame here. Its rad that you are putting so much work into your car. From the looks of the oil cooler ducts in the bumper, the holes are much smaller than the ducts that you made. If you look at the factory or r-magic ducts they use a method of making the initial opening smaller than the area that is sealed to the oil cooler. The reason for this is to create a pressure change from the front of the cooler to the back of the cooler. Basically, at higher speeds you have too much air going to the cooler and it cant get out the back because of the pressure created, so in order to fix this problem they make the inlet hole smaller than the surface of the cooler. Its probably done with a percentage of the surface of the cooler being reduced by a specific percent or some complicated formula. Anyway by making the initial opening smaller than the surface of the cooler, it creats a venturi effect actually helping the air get pulled through the cooler. Just thought this might help you out. Seems like you have the knack for making these things, so i thought i would give you a little technical data to help improve your designs. Good luck!
hsitko is offline   Reply With Quote
Old 12-19-2008, 05:26 AM   #12
rotaryextreme
i like spinners
rotaryextreme's Avatar
rotaryextreme is on a distinguished road
Fine example of cunstructive criticisim.
The ingenious and decidedly weird Wankel rotary engine works by using internal combustion to bounce a fat metal triangle around inside a hollow metal kidney bean, which hula-hoops around a central shaft to generate power.--- Jalopnik www.rotaryextreme.com, after more then a 2 year break, Rotary Extreme Re-opens 9/11/08.
rotaryextreme is offline   Reply With Quote
