Old 02-14-2010, 12:04 AM   #1
RICE RACING
Don Mega
RICE RACING's Avatar
13B-REW power references
http://translate.google.com/translat...m%2Findex.html
^ This has to be one of the best resources of honest power outputs for 13B-REW motors running T04R and twins around, all of the powers are calculated back to "engine power" using a 1.15 conversion on the dynapack and boost is listed in kg/cm.
Here also is some material from my own web site with dynapack dyno's with no correction factor (power at hubs listed) http://www.riceracing.com.au/water-injection.htm
Standard 13B-REW in the turbine TO4R ( Stock cut-back)
Boost: 1.32k   トルク:57.5kg/5930rpm馬力:524.0PS/7024rpm Torque: 57.5kg/5930rpm horsepower: 524.0PS/7024rpm
ブースト:1.2k Boost: 1.2k   トルク:55.0kg/5785rpm馬力:485.3PS/6988rpm Torque: 55.0kg/5785rpm horsepower: 485.3PS/6988rpm
ブースト:1.1k  トルク:51.3kg/5608rpm  馬力:459.4PS/6633rpm Boost: 1.1k torque: 51.3kg/5608rpm horsepower: 459.4PS/6633rpm
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
Last edited by RICE RACING; 02-14-2010 at 12:11 AM. Reason: Included some ref material from dynapcks on my site
Old 02-16-2010, 06:56 PM   #2
RICE RACING
Don Mega
Stock port 3mm seals running HKS T51R on 1.1~1.2 bar boost dynapack no TC factor (power at hubs) = 456hubhp ~524bhp
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
Old 02-16-2010, 07:02 PM   #3
RICE RACING
Don Mega
My old 1st gen 13B S5 block street ported, T04S = 351hubkw = 478hubhp ~ 550bhp
Boost dyno log of Autronic ECU 2002 vintage (sub 20psi boost) water injected
605m above seal level test facility
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
