Old 02-04-2010, 10:18 PM   #1
scottie0330
scottie0330 is on a distinguished road
intake manifold valve
Hello .i just got a 04 rx8 and already in love.however i know nothing about the motor yet.the light came on and i had it teasted and it said the intake manifold valve was stuck open.can anyone tell me if this is a major problem and what to do about it. thanks
scottie0330 is offline   Reply With Quote
Old 02-11-2010, 02:53 AM   #2
Tech B
Tech B is on a distinguished road
The valve in question controls the use of your variable intake manifold. As you move into higher loads/rpms, the intake manifold uses a valve to close one set of runners more efficient for low end and opens a better breathing set for high rpm. Generally the cause is debris buildup inside the manifold.
Tech B is offline   Reply With Quote
Old 02-11-2010, 09:04 PM   #3
scottie0330
thanks for replying.this would probley have something to do with me getting terrible gas milage right?im trying to figure this out without going to the costly dealership.is thir a way to clean it?i was told the you wassnt suppose the run the gumout fuelsystem cleaner in rx8's
Old 02-26-2010, 12:35 AM   #4
reaper
2slow4u
reaper's Avatar
reaper is on a distinguished road
i could see this causeing lower gas mileage.
i would check for vac leaks first. then i would move to defective equipment (something is proly broken) then i would clean it with something.
G.L. with the fix, keep us updated
my hoarse is amazing
sincityrotary.com
a place for las vegas rotary enthusiasts
reaper is offline   Reply With Quote
