Old 01-30-2010, 10:13 PM   #1
TS87FC3S
Ask Me About My WANKEL!!!
TS87FC3S's Avatar
TS87FC3S is on a distinguished road
New Member, New to rotary
Hey my names Trevor, buying my first rx7 next weekend.. it is a 1987 GXL, 5 Speed.. silver with blue interior. needs some TLC and it Needs a clutch so any tips there would help, im currently in college for auto tech and my roomate owns a 1983 rx7 so im slowly learning about these cars. i just know im in love with mine.
TS87FC3S is offline   Reply With Quote
Old 01-30-2010, 10:26 PM   #2
TS87FC3S
TS87FC3S's Avatar
pics just remember she is rough but im getting a good deal
Old 01-30-2010, 10:36 PM   #3
Looks like a decent S4.
Check out the FAQ at the top of the 2nd gen section. Lots of good info there!!
Old 01-31-2010, 01:03 AM   #4
TS87FC3S
TS87FC3S's Avatar
im wanting to take off the power streein pump, ac compressor, air pump, and rats nest (all emmisions actually).. any tips would be greatley appreciated and does anyone know what all to do, to do away with the rats nest, and what do i need to do when unhooking the ps from the rack? also i will probable be removing the omp and just running premix any ideas on ratio?.. and what about removal of pd i really dont want an engine fire..
Old 01-31-2010, 03:18 AM   #5
RE_guru
RE_guru's Avatar
RE_guru is on a distinguished road
on the pwr steering just loop the lines coming out of the rack back into the rack.
on the pulse damper i would recomend the aeromotive FPR it has a pulsedamper built in so u don't have to worry about injector leaks like u sometimes get when u just delete it. also all rotary and any modded car should have a fire extinguisher u may not need it but when u need it you will be glad.
Rats nest isn't too bad on the N/A cars but block off plates and vacuum plugs and silicone vacuum hose for the stuff u still need banzai makes great block off plates i especially like the OMP block off kit. when u delete the OMP use smokeless ashless 2 cycle normally marine 2 cycle has both these i use quicksilver that u can get at any walmart. the mixture is 1oz. per gallon of gas if you took out the OMP. If u don't remove the OMP u can still premix u just use 1/2oz. per gallon of gas. just don't forget that u have to premix the whole tank the first time u mix and after that u only mix for that gas u are about to add.
'94 Mazda Rx-7 montego blue
'88 Mazda Rx-7 se (SOLD)
'04 Mazda Rx-8 GT 6spd (daily)
Control Freaks www.cfdrift.com
All Your apex R belongs to US!
RE_guru is offline   Reply With Quote
Old 01-31-2010, 09:39 AM   #6
Go to www.rotaryresurrection.com
Click 2nd Gen, then go to the Tech tab.
All you need to know is there!!
Old 01-31-2010, 04:22 PM   #7
TS87FC3S
TS87FC3S's Avatar
Thanks both were big help now just one last thing i need to know is my engine is the 6 port and i want to do away with the air pump and new exhuast what do i have to do to keep the 5th and 6th ports working
Old 02-01-2010, 12:35 AM   #8
RE_guru
RE_guru's Avatar
u have an s4 which operates the 5th and 6th ports off exhaust backpressure so u can remove the air pump. on the s5's the ports were actuated by the air pump. with ur car just make sure if u buy a header that it is for the 86-88 N/A engine and has the backpressure tube for the ports. the racing beat header does but the racing beat "road race" header doesn't have the backpressure tube.
