Old 01-29-2010, 12:49 AM   #1
MAZDAT
MAZDAT's Avatar
MAZDAT is on a distinguished road
Carb adjustment
I have a totally stock 73 Rx2 with a 12a and twin dizzy, Does anyone know how to adjust the stock carb on this thing, any info greatly appreciated
MAZDAT is offline   Reply With Quote
Old 01-29-2010, 12:46 PM   #2
rx4ur7
Rotary since 1972
rx4ur7's Avatar
1.5 top 2.5/3.5 bottom are factory settings. Top screw is air, bottom fuel. That should get you going as long as someone has not played with throttle plate. Top is used for idle setting, bottom for emissions.
Old 01-29-2010, 01:51 PM   #3
Kentetsu
Kentetsu's Avatar
Sterling is our resident expert. He also has a lot of information built up over at www.sterlingmetalworks.com
The settings listed above should get you close, but for fine tuning take a look at the tuning section at the site listed above.
Good luck.
Old 01-29-2010, 05:46 PM   #4
MAZDAT
MAZDAT's Avatar
I'll try it, I just needed direction on how to do it, I really appreciate it!! Thanx
Old 02-15-2010, 12:58 AM   #5
rx4ur7
Rotary since 1972
rx4ur7's Avatar
I do the fine tuning with an exhaust analyzer as all street registered vehicles that leave this shop have to pass IM240.
And yes from what I hear and have seen Sterling is the top modifier now.
Old 03-21-2010, 05:43 PM   #6
jerry
jerry is on a distinguished road
does the 1985 model have two adjustment screws, i only see one
jerry is offline   Reply With Quote
Old 03-22-2010, 11:25 AM   #7
Kentetsu
Kentetsu's Avatar
One on the body of the carb (idle mixture), and one that is kind of hidden under the linkage at the back of the carb (idle speed). That one, you have to get down low, practically resting your chin on the driver's side fender, in order to see it.
Old 03-22-2010, 03:51 PM   #8
fire85gslse
fire85gslse's Avatar
My rx2 did not have a Nikki stock, so check yours to see if it is a hitachi. Then from there people will be able to help more. Not sure if the sterling site will help with a hitachi.
Old 03-23-2010, 10:27 PM   #9
MAZDAT
MAZDAT's Avatar
my has NIKKI on the side
Old 04-06-2010, 10:24 PM   #10
jerry
did hitachi build carbs for stock 1985 rx7`s, just assumed it was a nikki, cant find idle adjust screw, looks just like a stock nikki from pics
