Old 01-27-2010, 06:20 PM   #1
prican
prican is on a distinguished road
speedo help
i would like to go with electronic speed instead of mechanical for my project all i find is ford and gm pulsating senders does anyone know what part i can use to complete this on my project?
prican is offline   Reply With Quote
Old 01-27-2010, 08:09 PM   #2
i need a little more detail as far as what your trying to do. What transmission are you planning on using? Also, are you trying to get the Mazda speedometer to cooperate with an electrical sender?
Old 01-27-2010, 08:34 PM   #3
prican
i have a suzuki samurai with a 12a and Im getting a custom dash an would like to get all new gauges the set that i found and want to buy come with an electronic speedo.... this is the onlysender unit i keep finding to go with the gauge. will it fit? threads are 7/8 18
Old 01-27-2010, 09:01 PM   #4
i cant look at the link here at work. But im not too sure how you would adapt from a oem mechanical source. Most of the styles i have seen used for custom applications revolve about a magnetic pickup
Old 01-27-2010, 11:14 PM   #5
prican
how would this magnetic custom setup works where could i get this set up
Old 01-27-2010, 11:17 PM   #6
something like this. might have to do some more research into it all though
http://www.summitracing.com/parts/SWW-82646/
Old 01-28-2010, 12:24 AM   #7
prican
these are the ones i was looking at
http://www.summitracing.com/parts/VDO-340011/
http://www.summitracing.com/parts/CYB-8901/
http://www.summitracing.com/parts/SWW-82527/
and there is a couple more but i dont know if the threads are the same
Old 01-28-2010, 12:28 AM   #8
im unsure how it would operate in our transmissions being that ours is meant for mechanical drive and those american transmissions listed i have no information on. I dont know if it would adapt or is a replacement for an oem electrical system.
