Old 01-25-2010, 06:19 PM   #1
mazdadude7
mazdadude7's Avatar
mazdadude7 is on a distinguished road
need stock radio diagrams
My harness was cut and I have a stock radio. I want to test it before I go through all the trouble of repairing the harness, so does anyone have a diagram of the plug and where everything goes, thanks
mazdadude7 is offline   Reply With Quote
Old 01-25-2010, 06:37 PM   #2
Ender
rotors excite me
Ender's Avatar
The FSM has some helpful diagrams. It will be in 'body electrical'.
http://foxed.ca/foxed/index.php?page...nual#secondgen
'87 TII
rTek 2.1 awaits a tune
Originally Posted by need RX7
360 gamertag: quick Tii
Old 01-26-2010, 10:16 AM   #3
RX_Spec
Respect the Seven
RX_Spec's Avatar
RX_Spec is on a distinguished road
Constant 12V+ Blue/Red
Switched 12V+ Blue/White
Ground n/a
Illumination Red/Black
Dimmer n/a
Antenna Left Rear
Front Speakers 4" Dash
Left Front (+) Blue
Left Front (-) Blue/White
Right Front (+) Blue/Red
Right Front (-) Blue/Yellow
Rear Speakers 6 1/2" Side Panels
Left Rear (+) Blue/White
Left Rear (-) Blue/Green
Right Rear (+) Blue/Red
Right Rear (-) Blue/Green
There ya go full car radio side harness!
1990 GTU w/ near future Cosmo swap
2007 Chevy Cobalt
Xbox360 GamerTag- RXSpec
Learning a new Rotary issue everyday
RX_Spec is offline   Reply With Quote
Old 01-26-2010, 09:58 PM   #4
mazdadude7
mazdadude7's Avatar
Thanks for all the help anyone have a picture of a plug I dont have one...
Old 01-26-2010, 11:49 PM   #5
Ender
rotors excite me
Ender's Avatar
The FSM shows the backsides of the units where the plugs go.
'87 TII
Old 01-27-2010, 05:50 PM   #6
mazdadude7
mazdadude7's Avatar
Thanks, I started to look @ the fsm but it failed to load so i didn't get to check it out yet. Thanks again though for the heads up
Old 01-28-2010, 08:08 PM   #7
Ender
rotors excite me
Ender's Avatar
First chance you get it to load just save the whole thing so you'll have it in the future. I tried to use the link where I got my copy, but it was no longer in use otherwise I'd have given you that. If you have an S4 TII like I do send me your email address and I'll send you the FSM.
'87 TII
Old 01-28-2010, 09:08 PM   #8
If it is an S5, you can get the factory style plugs off of MANY Mazda's from the 90's. My Millenia, Miata, and FC all used the same plugs. Some just had more pins than others.
Old 01-28-2010, 09:30 PM   #9
mazdadude7
mazdadude7's Avatar
Thanks dj! didnt even think of that.... I knew we kept you around for a reason.
I did test the radio and it powers up fine the bulbs are blown so Im going to be replacing them with leds ,my friend has all the bulbs already and likes to do that kinda stuff.
On a different note I am working on a metal stereo pannel to fit an aftermarket radio and 3 gauges or in my case one gauge and a turbo timer. I already have a protype mocked up just gotta make a real one. I will post pics of the cardboard mock up for a few laughs later.
Old 01-28-2010, 10:08 PM   #10
Ready for me to blow your mind again
DDMworks makes what you are wanting to build for a NA (1st gen) Miata that should fit FC's as well.
Old 01-31-2010, 06:27 PM   #11
mazdadude7
mazdadude7's Avatar
My mind has been blown! your amazing!
http://www.ddmworks.com/miata/interi...surrounds.html
only thing is the mounting points are not correct but they could be fixed pretty easy.
