Old 03-18-2008, 09:31 PM   #1
Renesis
~Mazda~Girl~
Renesis's Avatar
Renesis is on a distinguished road
Decal Question
i hope this belongs here. Anyways I have painted my calipers blue and ordered some silver decals from Xenonmods.com I plan to put the word RX-8 on my calipers I was wondering if anyone knows the best way to put them on and make sure they don't fall off.
~~Jennifer~~
2000 Mazda MX-5 Miata LS
Renesis is offline   Reply With Quote
Old 03-18-2008, 09:37 PM   #2
I8U
KONI Challenge Crew
I8U's Avatar
I8U is on a distinguished road
Honestly, there really isn't a good way to apply those. The decals are a plastic, the heat alone from the brakes will destroy them. Here's the best way to do this...
Prep and paint the caliper whatever contrast color your want, then let that cure, then apply the decals you want and paint the caliper again with a different color and let that dry, then pull off the decals and now you would be good to go. It's like using the decal as a stencil.
04 TiGray RX8 MT, LS2 coil setup, 3" midpipe, HKS Hi-power 3" exhaust, TEIN S-Techs, Hotchkis Adj F/R sways, K&N Typhoon V2, Steel braided brake lines, Redline drivetrain fluids, ATE Super Blue brake fluid, Cobalt XR2/GTS brake combo, MB Motorpsorts Weapons 18x9 +45 offset, 275/35's
I8U is offline   Reply With Quote
Old 03-18-2008, 09:44 PM   #3
Renesis
~Mazda~Girl~
Renesis's Avatar
Ahh I see. so if i wanted the color in silver paint the caliper in silver with the decal on then paint them blue again then peal the decal off?
another friend of mine had suggested sticking them on and using high temp clear coat over them *shrugs*
~~Jennifer~~
Old 03-18-2008, 09:45 PM   #4
-xlr8planet-
-xlr8planet-'s Avatar
I had decals in my calipers, I painted the calipers, applied the decals and clear coated everything (high temp clear coat in a can)
They holded for several years
Old 03-18-2008, 09:48 PM   #5
Renesis
~Mazda~Girl~
Renesis's Avatar
ahh so hightemp clear coat i could try? and if that dont' work i can do the stencil thing?
~~Jennifer~~
Old 03-18-2008, 10:21 PM   #6
-xlr8planet-
I used krylon
Not a problem. After several years it turned yellow and started to peel off like skin
Old 03-18-2008, 10:33 PM   #7
Renesis
~Mazda~Girl~
Renesis's Avatar
ouch. well i'll give it a shot it's much easier than painting everything all over again. Thanks for the help
~~Jennifer~~
Old 03-27-2008, 09:04 AM   #8
praxis1301
praxis1301's Avatar
praxis1301 is on a distinguished road
9 days late... did ya do it already? if so how'd it turn out?
if not... you could make a stencil using the decals and paint the letters on that way...
what did you use to paint them in the first place... i'm about to re-paint mine and wanna try something else...
praxis1301 is offline   Reply With Quote
