Old 01-24-2010, 02:37 AM   #1
jamespond24
jamespond24 is on a distinguished road
Need Help no power when key in ignition
Don't know what happen but for some reason when the key is in the ignition there's no power? I checked all the fuse and everything is fine. So what could cut power to the igntion switch?
jamespond24 is offline   Reply With Quote
Old 01-24-2010, 10:55 AM   #2
Ender
rotors excite me
Ender's Avatar
A bad ignition switch. There are probably a number of things that could cause it though. Did you check the fuses in the engine bay? Maybe get your battery tested.
'87 TII
rTek 2.1 awaits a tune
Originally Posted by need RX7
360 gamertag: quick Tii
Old 01-26-2010, 12:25 AM   #3
jamespond24
it turns out to be the main fuse
Old 02-16-2010, 09:34 PM   #4
Gabriel82
サバンナFC3S RX-7
Gabriel82's Avatar
Gabriel82 is on a distinguished road
oh then someone probably put the ground to the positive and positive to ground. I accidentally did that once and blew my main fuse.
Series 5 GTU
Gabriel82 is offline   Reply With Quote
Old 02-16-2010, 10:48 PM   #5
Ender
rotors excite me
Ender's Avatar
My dad blew my main fuse by digging around with a screwdriver and shorted the 12+ terminal on the alternator to ground (which is the same as directly connecting the 12+ to - on the battery). I was so mad, it was my first day with the car and I had to leave it at their place overnight because the shops were all closed by then. I've heard that switching the + and - cables on the battery can do a lot more damage than just blowing the main fuse. Regardless, DON'T DO THAT and DON'T SHORT 12+ TO GROUND and this should rarely happen.
'87 TII
