Old 01-10-2010, 11:58 PM   #1
IH8DSM
IH8DSM's Avatar
Need rotary guru help
Ok the truck is a 74 repu with a 13b, as of right now its got a holley carb, a header and a rebuilt motor. The motor is street ported and made with atkins springs/seals and fel pro gaskets except for the oil control rings.
Heres the problem, it starts, runs, drives, idles with no problems but once its warmed up and you turn it off or stall it, then thats the end of it. it wont start up again till its cooled down. After its cooled down it will start and run again till its warmed up again. We're clueless at this point we've tried three different carbs ( niki, side draft, and now the holley) two completely different motors (had a fresh rebuilt one in there previously did the same thing) 3 different starters, different distributor, different igniters. Battery is good, alt is good. Used seperate parts for both motors similar problem. New fuel pump, good fuel pressure. Maybe 200 miles since rebuild, everything in side checked out fine.
So at this point getting really frustrated, So any ideas would be helpful.
Old 01-11-2010, 02:28 AM   #2
Rogue_Wulff
Non Member
Not enough miles on the engine. It takes a while for a fresh engine to build enough compression for a hot start.
Old 01-11-2010, 12:50 PM   #3
IH8DSM
IH8DSM's Avatar
Think that could be the case? Never had that problem on any of the other rebuilds/
Old 01-11-2010, 02:04 PM   #4
dudemaaan
dudemaaan's Avatar
check the compression just to see what it is, if used housings and such were used then compression won't be as high and it can take longer for everything to seal up. Hot start problems is usually a sign of weak compression, too much fuel in these situations can also make it harder to start.
Old 01-11-2010, 02:09 PM   #5
Rogue_Wulff
Non Member
As stated above, new seals and used housings tend to need 1000-1500 miles in order to fully seat in together. I've seen many rebuilds that were nearly impossible to start hot, but started fine cold. The issue usually went away after 1000-1500 miles.
Even minor carb issues can greatly increase the difficulty in hot starting a rebuild.
Old 01-12-2010, 03:58 PM   #6
Kentetsu
Kentetsu's Avatar
Any chance that timing could be the issue? That's all I can think of that hasn't already been mentioned. Good luck!
Old 01-14-2010, 02:41 AM   #7
91GSL-SE
At the dirt track.
91GSL-SE's Avatar
91GSL-SE is on a distinguished road
Any fuel lines getting hot? Could be vapor lock?...
Also is your fuel system vented?
Rollin like a reuleaux. Unstoppable.
91GSL-SE is offline   Reply With Quote
