Old 01-04-2010, 10:21 PM   #1
-Six-
-Six- is on a distinguished road
De-ABS-ing my car...best solution?
Alright, so I already had to deal with the leaking ABS pump; tossed it out and put in an ugly block adapter kit to reconnect the loose lines. What do I need for a more elegant/functional solution? Is it possible to swap in non-ABS rx-7 hardlines, is it more involved than that? Any other changes I might not have considered? Thanks in advance.
-Six- is offline   Reply With Quote
Old 01-05-2010, 12:42 AM   #2
Swapping in the Non-ABS hardlines would be the way to go. Even better would be to get lengths of the SS tube and bend up your own, then have it double-flared. That woul be the best. That's what I did.
Or you can get some SS braided lines from Goodridge as well. They make awesome stuff.
Just out of curiosity, what are you doing with all te old sensors and rings? I may want them if they are going to the can
Old 01-05-2010, 12:44 AM   #3
custom lines... sounds sweet.
Old 01-05-2010, 08:33 AM   #4
Custom lines would be sweet, but kinda $$$ and not needed.
Junk FC's are everywhere, and it takes 5 minutes to get the lines out.
Old 01-05-2010, 10:13 AM   #5
Custom hardlines aren't that expensive. The custom Goodridge -3AN stuff can get expensive and I've ALLLLLLMOST ordered some with $45 fittings crimped onto the ends.
SS Hardlines can be found at a bunch of different places. I think I got mine from http://www.classictube.com/
I'd be leary about reusing 20+ year old brakelines. Mine were getting a little rotten in the rear and I'd hate to loose brakes when you need them.
So, old ABS parts
Old 01-05-2010, 05:50 PM   #6
-Six-
So, old ABS parts
I would be leary of the old lines myself, I would opt for new ones either way. Old ABS parts I still have if you are interested, but I have to remove them all. Probably won't happen that soon, it's been 10-15 degrees every weekend and it has a way of killing my motivation to work in the garage.
Old 01-05-2010, 06:09 PM   #7
You need a heater Where are you located? I'll pull up some FSM, microfische type pics and show you what I need. Thanks
Old 01-05-2010, 07:05 PM   #8
-Six-
Definitely need a heater. I am located in Chicago, IL. Let me know what you need, maybe we can work out some trades, I am sure I will need something you may have.
Old 01-05-2010, 10:30 PM   #9
-Six-
What about proportioning valve, master cylinder...is there anything there I need to consider or even options that I have?
Incidentally, does anyone have a good website for OE parts?
Old 01-13-2010, 07:33 PM   #10
Best website for stock parts to look up prices and part numbers is Mazdatrix. Ray @ Malloy Mazda will usually beat thier prices though
Posted here to be linked in a PM
Old 01-13-2010, 08:03 PM   #11
-Six-
replied to PM
