Old 02-24-2014, 08:50 PM   #301
Fendamonky
Get off my lawn!!!
Fendamonky's Avatar
Was out one night and developed a terrible stumble. Thought I popped it would not idle. Next day runs fine for the next week started the teardown without finding out what. So I figure I might as well start over as the parts to rebuild should be very minimal. I hope....
The motor had break in miles I know as I did one oil change but i would be surprised if it has 3,000 on it.
Ah, gotcha. Wiring good, injectors ok, ignition happening right? Dude I don't know if I'd even crack that thing open...118/118/116 aint bad compression in the slightest...
Originally Posted by Cheebz
Cool got a place nailed down at least.
Yeah, I've got a feeling that the Landlord/property rental company are going to be a pain in the dick... But ideally this will only be temporary, and we'll be able to move on to somewhere more permanent before the end of the summer. I can't WAIT to get all my finances in order and buy a house... I'll make sure it's got a big garage (with a high ceiling) and totally install a lift
Bianca wants a big kitchen (for more baking) and I want a big garage (for moar cars)... I think we'd be good with a 500sq/ft house if it had a 100sq/ft garage and a 50sq/ft kitchen
Yeah, that was just me being a dick No way for bearing material to get into the coolant system......
Fucking asshole
'94 Touring - Cursed
'96 NA Miata
'14 Mazda3 Hatch
'14 Aprilia RSV4 R
Old 02-24-2014, 09:05 PM   #302
chibikougan
chibikougan's Avatar
Yeah I hear ya my brain just doesn't want to leave it. its a way off either way.. We can continue in BAW so we don't muddie your thread.
Old 02-25-2014, 10:01 AM   #303
RXtacy
RXtacy's Avatar
The only reason I wouldn't reuse them (provided they will take fresh bearings) is because RX-8 e-shaft. If I go with the 8 e-shaft I'll also go with the accompanying stat gears.
The RX-8 stat gears are the same as the FD. They are just cheaper to buy new.
Fucking asshole
Math fail. Those are tiny spaces for both. Single car garage is ~336 sqft, and a 5'x10' kitchen would be terrible.
93 Frozen Grey Metallic FD
Build thread here
17 Camaro SS 1LE
04 RX-8 GT
but I'm getting old
Old 02-25-2014, 10:31 AM   #304
Fendamonky
Get off my lawn!!!
Fendamonky's Avatar
You sure? I thought the window alignment was slightly different.
Ok, so I screwed up on the dimensions off the top of my head...
'96 NA Miata
'14 Mazda3 Hatch
'14 Aprilia RSV4 R
Old 02-25-2014, 10:37 AM   #305
RXtacy
RXtacy's Avatar
The front is identical, the rear doesn't have the oring grove so you have to use sealant. There's no "upgrade", other than they are cheaper new.
Build thread here
17 Camaro SS 1LE
04 RX-8 GT
but I'm getting old
Old 02-25-2014, 02:55 PM   #306
Negative.... while the stat gears themselves are the same, the bearings are not. If mixing and matching 13B-REW and 13B-MSP eshaft and bearings, tolerances MUST be checked. Also, there is a taper in the rear of the MSP shaft, and like you said, there is no o-ring so it must be sealed. They are minor differences but they need to be addressed if you're a cheap fuck. If you just buy the MSP shaft and stat gear/bearing assemblies, you just slap them in.
Old 02-25-2014, 03:00 PM   #307
RXtacy
RXtacy's Avatar
Incorrect, the bearing part #'s are the same. The thickness ranges are the same. I do agree that clearance should be checked regardless though. If you recall MSP shaft in my FD stat gears checked out g2g.
Build thread here
17 Camaro SS 1LE
04 RX-8 GT
but I'm getting old
Old 02-25-2014, 03:24 PM   #308
Yes, PN's are the same but when you buy a stat gear with bearing, the supplied bearings are of different clearances though.... at least the ones we got @ S1 were.... hence... they all need to be checked... or should... most people don't.... they just say... not enough copper showing to throw these away
Old 02-25-2014, 05:17 PM   #309
Fendamonky
Get off my lawn!!!
Fendamonky's Avatar
Wait... so if the metal gear itself is the same, and its just the bearings which are different... I could just pick up the rx-8 bearings to match the rx-8 eshaft??? I'm thinking pressing in the different bearings would be much cheaper than buying the entire set, IF it would work and that's really the only difference...
Yes?
'96 NA Miata
'14 Mazda3 Hatch
'14 Aprilia RSV4 R
Old 02-25-2014, 05:19 PM   #310
Fendamonky
Get off my lawn!!!
Fendamonky's Avatar
I honestly don't plan on getting them as an "upgrade" but rather as a matching set for the 8 e-shaft. But if swapping bearings would make them all line up right...
'96 NA Miata
'14 Mazda3 Hatch
'14 Aprilia RSV4 R
Old 02-25-2014, 07:08 PM   #311
Fendamonky
Get off my lawn!!!
Fendamonky's Avatar
So I was reading over the FSM this evening when there was a knock at my door....
It was the Fedex guy
He brought me a little something-something..
A Wild Life Racing ECU has appeared!
'96 NA Miata
'14 Mazda3 Hatch
'14 Aprilia RSV4 R
Old 02-25-2014, 07:46 PM   #312
RXtacy
RXtacy's Avatar
This I would definitely believe. Would imagine they ship with the thicker range bearings due to the slightly smaller diameter of the MSP shaft. Completely agree they need to be checked.
Build thread here
17 Camaro SS 1LE
04 RX-8 GT
but I'm getting old
Old 02-25-2014, 07:47 PM   #313
RXtacy
RXtacy's Avatar
Nice ECU Levi
Build thread here
17 Camaro SS 1LE
04 RX-8 GT
but I'm getting old
Old 02-25-2014, 08:15 PM   #314
Fendamonky
Get off my lawn!!!
Fendamonky's Avatar
Thanks Mike
Now if only I hadn't recently gotten slammed with life expenses that stole all the money I was going to use for building this things harness (and engine)!! lol
'96 NA Miata
'14 Mazda3 Hatch
'14 Aprilia RSV4 R
Old 02-26-2014, 02:30 AM   #315
Make sure you pull all my pubes out of the connector that I left for you
Soooooo we're saying the same thing, you just like to argue?
