Old 02-25-2014, 02:55 PM   #10
Negative.... while the stat gears themselves are the same, the bearings are not. If mixing and matching 13B-REW and 13B-MSP eshaft and bearings, tolerances MUST be checked. Also, there is a taper in the rear of the MSP shaft, and like you said, there is no o-ring so it must be sealed. They are minor differences but they need to be addressed if you're a cheap fuck. If you just buy the MSP shaft and stat gear/bearing assemblies, you just slap them in.
