Old 02-20-2010, 05:12 AM   #16
Stredrotor
Stredrotor is on a distinguished road
I got the exhaust manifold back from having the sealing faces machined flat so I have been able to make the 3 1/2 inch dump pipe, a tight fit but it clears . Just have to make the flanges to bolt the exhaust system to it. (When I make the exhaust system.)
After I weld the flanges on, the turbo exhaust housing, manifold and dump pipe will be sent off to be ceramic coated. Should help keep the heat down and looking good.
.....also mounted the coils
Stredrotor is offline   Reply With Quote
Old 02-21-2010, 05:29 PM   #17
pdxhak
pdxhak is on a distinguished road
Awesome build!
pdxhak is offline   Reply With Quote
Old 02-21-2010, 08:41 PM   #18
pineapplesoymilk
Want Boost!!!
pineapplesoymilk's Avatar
pineapplesoymilk is on a distinguished road
good luck get some videos up when its finished!!!
05 se3p, HKS Hi-Power cat back, blacked out emblems and tail lights and marker lights, Voodoo shift knob and eyelids many more to come this winter.
pineapplesoymilk is offline   Reply With Quote
Old 02-22-2010, 09:59 AM   #19
Gregory Casimir
damn dude, that is gonna be sick!
Old 02-24-2010, 06:03 PM   #20
Proxy One
Victory Is Mine
Proxy One's Avatar
Proxy One is on a distinguished road
Damn nice build, ive always had a soft spot for Rx4's and this one is sure to be the nicest ive seen.
www.dealsgaprotaryrally.com
1994 Rx7 White 2001 RZ GT35R'd
1972 Rx2 Orange Coupe 5spd
2006 STi
1986 Buick GN
Proxy One is offline   Reply With Quote
Old 03-15-2010, 07:54 PM   #21
vincentrx7
20b FD
vincentrx7's Avatar
vincentrx7 is on a distinguished road
A bit off subject, but will a RX4 bellhousing fit a 20b? And what does a series 5 trans come out of? Nice build by the way.
Bobby
'93 20b RX-7
vincentrx7 is offline   Reply With Quote
Old 03-16-2010, 04:26 AM   #22
Stredrotor
An RX4 bell housing would fit a 20b but the later FC Turbo models onwards gearboxes run a larger flywheel so have more friction surface the clutch to grip.
Sorry, you guys know the series 5 RX7 as the second version of the FC RX7 model. It is often related to in Australia as First Gen RX7 as Series 1,2 and 3 Second Gen (FC) Series 4 and 5 and Third Gen (FD) as 6,7 and 8.
Old 03-16-2010, 09:01 PM   #23
vincentrx7
20b FD
vincentrx7's Avatar
thanks for the info. I looking for options on transmissions to hold a 20b's power.
Bobby
'93 20b RX-7
Old 03-16-2010, 09:38 PM   #24
We use that to. We usually just say "S5" though.
Old 04-04-2010, 01:55 PM   #25
need RX7
Clean S4 Nutswinger
need RX7's Avatar
Amazing. Updates?
Old 04-04-2010, 09:20 PM   #26
Stredrotor
Haven't had much time to work on it lately. I have decided to remake the dump pipe it came a bit too close to the brake lines.
I am chasing a throttle body so I can make a start on the water to air intercooler setup.
Plus I said yes to make a 20b turbo manifold for a guy in Melbourne but it's extra cash and I learned a few things from making mine.
Old 04-11-2010, 07:16 PM   #27
Breckboarder55
Breckboarder55 is on a distinguished road
Excellent work man! I look forward to seeing some updates.
1955 Dodge Royal Lancer: (waiting for restoration)
1987 RX7 T2: Haltech, lots of fuel, 62-1, exc
1999 Wrangler: 33" M/T, skids, 3.5" lift,exc
1987 Mazda RX-7 Base: resurrecting from dead
Breckboarder55 is offline   Reply With Quote
Old 04-18-2010, 10:32 AM   #28
kbken62
kbken62 is on a distinguished road
What are you going to do for brakes and rear end?
kbken62 is offline   Reply With Quote
Old 05-22-2010, 12:15 AM   #29
Stredrotor
Not sure yet, like to have a good disk brake setup.
Here's a bit of an update not much but it's one step at a time .
Lashed out on a Westside Exhaust and Custom radiator and oil cooler combo.
Also a PWR barrel cooler, heat exchanger, filler spout and water pump I scored for a good price off ebay.
Now have to make some mounts for the radiator and heat exchanger and plumb up the barrel cooler.
Getting there ever so slowly.
Old 05-29-2010, 03:49 AM   #30
Stredrotor
Found a bit of time this arvo, so with the mounts welded on I mounted the radiator and made some trial mounts for the heat exchanger radiator.
Also had a bend welded onto the end of the barrel cooler to bring it in line with the radiator.
Waiting on a 135 degree bend from plasmaman to go up to the throttle body to finish it off the intake side.
20b, mazda rx-4
