Old 04-27-2016, 04:37 PM   #1
Originally Posted by project86 View Post
Looks like my power steering rack is leaking...... Boo. I like that it has power steering but knowing that it's leaking I wonder if I should just take the pump out and depower it. Driving with no power steering didn't really bother me in my 86..... But that was also a manual rack.
It's not too hard to rebuild. Bri-bri can walk you through it.
Old 04-27-2016, 06:20 PM   #2
project86
Can't.Make.Up.My.Mind.
project86's Avatar
I found his thread on de powering it. Seems like a pain but I don't think I want to shell out the money to try and fix it or have it repaired.
'90 GTUs
'06 Toyota Highlander Hybrid
'10 Toyota Prius
Old 04-27-2016, 07:13 PM   #3
project86
project86's Avatar
Turns out my weird shuddering is happening in more than just 1st gear. On my drive to get coolant flushed i noticed it quite a bit. Although it seemed to come and go in later gears. It leads me to believe that maybe something is loose. It feels like most of it is coming from under my seat.
'90 GTUs
'10 Toyota Prius
Old 04-28-2016, 10:57 AM   #4
Describe the 'shudder'.
Like the engine is missing? Clutch chattering? Suspension shunt?
Old 04-29-2016, 08:19 AM   #5
project86
project86's Avatar
Just to elaborate more on my inspection yesterday. I laid under the car for about an hour or so just looking around at stuff, trying to move it, etc. Nothing was obviously loose or easily moveable. Bushings are obviously worn which I'm sure is a contributing factor to the vibes I'm getting.
Bushings will be coming soon as well but i figured trans mounts would be a better first place to start. I ordered a new trans brace as well. I'm contemplating dropping the trans and just cleaning it up when i do the mounts. Its just nasty and has what smells like gear lube on it but I didnt notice any leaks. I guess it would be a good idea to drain it and refill as well. If i do drop the trans.. is there anything else i need to do before i put it back in?
'90 GTUs
'10 Toyota Prius
Old 04-29-2016, 09:03 AM   #6
GySgtFrank
Professional Stick Poker
GySgtFrank's Avatar
get snot slinging drunk.
Old 04-29-2016, 09:12 AM   #7
FC Zach
FC Zach's Avatar
There will be bolts missing if that happens!
1993 Yamaha GTS1000
1992 Celica Turbo AllTrac
1987 RX7 Sport
1979 Yamaha G1, KM24 powered
1975 Dolmar KMS4
Old 04-29-2016, 12:10 PM   #8
If it's trans mounts, it'll make a LOT of noise on shifts...
Anything from a thud to a BANG during the shift is your typical sign of failure.
It's uncommon that bad trans mounts induce a shudder during driving though, but this could be a symptom of something else...
Old 04-29-2016, 12:31 PM   #9
t_g_farrell
Waffles - hmmm good
t_g_farrell's Avatar
It could be a clutch or throw out bearing.
Old 04-29-2016, 12:56 PM   #10
project86
project86's Avatar
Indeed.
I was reading up on Mazdatrix about similar symptoms. now that you've said this though i guess ill have to think about something else. Trans mounts should be here in a day or two. I told them a joke in the comments section and they (Himni) upgraded me to 1 day shippings because i made them laugh haha.
I guess thats getting added to the list to then. So even though its happening when I'm off the clutch it could still be either?
'90 GTUs
'10 Toyota Prius
Old 04-29-2016, 08:28 PM   #11
Ugh.
Their stuff is crap...
Old 04-29-2016, 08:39 PM   #12
project86
project86's Avatar
Ugh.
Well that would have been nice to know. What's to bad about their stuff? Seems like it would be kinda hard to mess up a poly mount.
'90 GTUs
'10 Toyota Prius
Old 05-02-2016, 12:20 PM   #13
If we're talking about comparing it to the stock OEM ISOLATION type mount, then it's garbage...
Remember the old adage?
If it's too good to be true (i.e. cheap), then it is...
The stock type mount (this goes for the engine and trans mounts), are two studs attached to two plates of metal with a rubber sandwich in between them.
This allow both compression and pull forces to be absorbed by the mount itself.
All these cheap-ass vendors who sell this crap built these mounts that can only handle compressor forces; they do not isolate the pull forces, as you're asking against the bolt / fastener.
What does this all mean?
You get increased vibration through this cheap-ass mount...
It could possibly damage something else, as now your mount does not isolate tension forces...
You get an inferior mount, because they are too cheap to build a proper mount...
Anyone can get a block of (insert fav...rubber, polyurethane, nylon, UHMW plastic, aluminum, hockey puck) and drill a hole in it and slap on a nut and bolt...
Old 04-29-2016, 01:16 PM   #14
wiggle the shaft to check for u-joints and backlash
giggitty
Old 04-29-2016, 01:40 PM   #15
project86
project86's Avatar
giggitty
Wouldn't you rather me wait until you're around for me to wiggle the shaft?
'90 GTUs
'10 Toyota Prius
