Old 04-29-2016, 08:19 AM   #10
project86
Can't.Make.Up.My.Mind.
project86's Avatar
Just to elaborate more on my inspection yesterday. I laid under the car for about an hour or so just looking around at stuff, trying to move it, etc. Nothing was obviously loose or easily moveable. Bushings are obviously worn which I'm sure is a contributing factor to the vibes I'm getting.
Bushings will be coming soon as well but i figured trans mounts would be a better first place to start. I ordered a new trans brace as well. I'm contemplating dropping the trans and just cleaning it up when i do the mounts. Its just nasty and has what smells like gear lube on it but I didnt notice any leaks. I guess it would be a good idea to drain it and refill as well. If i do drop the trans.. is there anything else i need to do before i put it back in?
'90 GTUs
'06 Toyota Highlander Hybrid
'10 Toyota Prius
