View Poll Results: What oiling setup to use for racing
Leave it stock and run the right engine oil 0 0%
Leave it stock and add some pre-mix 8 53.33%
Disable the metering pump and pre-mix 6 40.00%
Other - I have posted a better idea 1 6.67%
Voters: 15. You may not vote on this poll
Old 04-26-2012, 10:30 PM   #16
sen2two
KTEC
sen2two's Avatar
I always use Protek-R. It's made by Pettit Racing. A well known and very well established Rotary shop.
what I have:
What I had:
Old 04-27-2012, 09:45 AM   #17
Luthor
FirstGen owner
Luthor is on a distinguished road
Running some good quality racing motorcycling 2stroke.
1980 RX-7 powered by:
Half-bridge S5 TII13bt+TII tranny, Precision 72mm, Autronic SM4+500CDI, Water inject++.
Luthor is offline   Reply With Quote
Old 04-30-2012, 11:03 AM   #18
magpiemini
magpiemini's Avatar
magpiemini is on a distinguished road
Ok I will use the OMP and some good racing two stroke oil premix. Premix at 1 oz per gallon of fuel.
Now see my next question about octane.
1984 RX7 GSL-SE
Building for the 24 Hours Of Lemons
magpiemini is offline   Reply With Quote
Old 04-30-2012, 06:13 PM   #19
Originally Posted by Garfinkles Motor Works View Post
My car is setup to inject Amsoil hp 2 cycle oil from a 3qt tank that I made .
Originally Posted by Pete_89T2 View Post
I did a similar setup on my FC, uses the Rotary Avaition OMP adapter and a 1.5 quart tank that I purchased. Here's a link to the "how to" write-up.
http://www.rotarycarclub.com/rotary_...ad.php?t=14945
You two should've voted
This is a great idea if you have a mechanical OMP or are using the stock ECU or an aftermarket ECU capable of driving the electric OMP. Unfortunately I have neither
I could get an S4 front cover and find a mechnical OMP and rig something up but I don't know how that works with the S5 front counterweight and it doesn't solve the problem that I only have 2/4 oil injector ports (custom intake manifold).
To the OP: I would say this is the best option for your SA/FB. You can run dedicated premix in an auxiliary tank and run some nice synthetic oil in the engine.
Front cover has nothing to do with counterweights.
Plug the other two outlets, roughtly 2x the oil will be delivered to the remaining ports
I run Idemitsu through an adapter through the OMP. Then about .6oz./gal in the tank. Has worked great and I'm probably one of the few people who have seen my rotor housings regularily so I can tell you which works and which "seems to work just fine"
Pre-mixing in the tank gives the added benefit of being able to disperse the oil throughout the combustion chamber rather than just on the tips of the apex seals.
Premix and OMP. Safer than sorry route. I haven't owned an FB in several years now (and I miss my old ones), but that is how I run in my Rx8 now.
And this coming from a guy with the best OMP and nozzles and LOCATIONS on any rotary
Old 12-02-2013, 02:52 PM   #20
Rot
Rot is on a distinguished road
pre mix
How long have you been using Amsoil HP 2 cycle oil!
Rot is offline   Reply With Quote
Old 12-02-2013, 05:42 PM   #21
Rotary Evolution
rotaryevolution.net
Rotary Evolution's Avatar
Originally Posted by magpiemini View Post
Thanks, found it. It seems the Marvel Mystery Oil is just as cheap as the TCW3 at O'Reily's so I bought some. So 1 oz per gallon (128:1) along with the omp?
MMO isn't much of a lubricant, and it isn't even remotely comparable to 2 stroke oil.
http://rotaryevolution.net
Old 12-02-2013, 09:32 PM   #22
I have used the PCV Technologies metering pump adapter with nothing but Amsoil for about 15 years on the 1994 that I have had for 17 years .
Old 10-07-2016, 08:02 AM   #23
I'd like to introduce you to my ban-hammer
Old 10-07-2016, 08:07 AM   #24
Fendamonky
Get off my lawn!!!
Fendamonky's Avatar
Without context it just looks like you're mad at Garfinkle
'94 Touring - Cursed
'96 NA Miata
'14 Mazda3 Hatch
'14 Aprilia RSV4 R
Last edited by Fendamonky; 10-07-2016 at 10:17 AM. Reason: Fucking (poor) grammar before coffee kicks in...
Old 10-07-2016, 09:49 AM   #25
I tired to keep the post there, but it would've required backing out, and going to the admin panel, and banning him the hard way... I decided it wasn't worth it..... especially because he probably saw it as he was online when his ass was banned
So just to clarify.... no I'm not mad at Garfinkle
