Old 02-20-2011, 12:03 AM   #16
I don't want to make it shine though, I'm trying to turn everything black. I've even thought about sandblasting my aftermarket pulleys and anodizing them. I believe they're aluminum anyway haha.
Thanks for the input guys. I guess I'll look into plating for the non-aluminum stuff then.
I believe there's a black cadmium plating option if you're looking for black.
Old 02-20-2011, 02:15 AM   #17
Uh huh,....... couldn't be when I opened the hood you went, wow that really does look good
Actually to be completely honest, no. A few years ago I decided to go all black, including under the hood, but until last year for the body and this year for the engine bay (since I have the engine out anyway) I didn't feel like stripping the car down to paint it LOL. Your engine bay does look good though haha.
Originally Posted by Prodigy View Post
Hey I can do that myself, and it's cheaper!!!!! No need to supply your own datalogit either
J.
LOL!!!
Awesome, thanks! I'll check into that. Hopefully someone around here can do it.
Old 03-01-2011, 03:54 AM   #18
So it looks like I'll be getting all the brackets and such electroless nickel plated. They will still conduct electricity so I shouldn't have any trouble grounding the pieces and I was told the trigger wheel won't have any problem feeding info to the crank angle sensors. I'll post up pics when completed.
I also got all my IC piping, manifolds and elbow powder coated and got the LIM and exhaust parts re-ceramic coated. Pic attached.
Old 03-01-2011, 08:52 AM   #19
NICE! LOVE IT!!! Can't wait to see her again. Who did the coating? SportTuner?
I'm going to have my the trigger wheels for my speed sensors Zinc plated I think. Who is doing the electroless nickle plating?
Old 03-01-2011, 12:22 PM   #20
To_Slow
Zinc plating is your best option, I offer the service gold or clear.
Min 100.00$ considering all parts are pre cleaned sand blasted.
That will include allot more than just a timing wheel.
I also offer anodizing to. min is 100.00$
Hope that helps..
Thanks
My link
Old 03-02-2011, 02:49 AM   #21
I took all the stuff to a place in Denver, Premier Coatings.
I guess he just changed his website, it didn't look like that just a few days again. Anyway, he's a good guy. I got everything done for $400.
As for the electroless...I dropped off all the pieces Monday to a place here in C Springs, Ximpak, but they were going to charge me $190 and they were backed up a couple weeks. There is another place in town that said they could do electroless nickel and they could have it done in 3 days and a lot cheaper, so I picked up the parts from Ximpak and dropped it off at Finishes Limited today. But as it turns out they can't do electroless nickel in black, so I decided to get the steel oxidized black and the aluminum anodized black. The only problem is the alternator casing and the PS/AC bracket have steel pieces in them that I have to get out before they can be anodized and I'm not sure that's possible. In any case, the oxidizing will cost $60 and the anodizing will be $65, so I'm saving quite a bit of money. I've thought about just getting the aluminum (stuff for anodizing) just powder coated instead though. Zico works at a place here in town that shares a building with a powder coating place that will give him a discount. I still need to get the water pump, pump housing and filler neck all done still anyway. I'd also like to get the PS pump done but I'm not sure there is a way to do it that won't do some damage to it somehow.
Hope that helps..
Thanks
Thanks for the offer, but I want to get this stuff done locally. Plus I want all black anyway.
Just out of curiosity though, why is zinc plating the best? I don't know much about all the different options. I did a search on them but there was so much info I just didn't have time to read it all.
Old 03-02-2011, 07:50 AM   #22
Cool, some of my parts may be there shortly as well, as soon as they get cut. Looking for some black as well on the steel trigger wheels I'm getting cut.
You might just want to have all those piece ceramic coated so they match the other pieces that you had done. I made the mistake a few years ago of sending all my intake and exhaust pieces out to get ceramic coated, then I powdercoated all the other brackets etc etc myself. Two different blacks, I wasn't pleased. Now everything that I powdercoated, I need to re-powdercoat with a different black.... which is fine as alot of the powder coated got beat up. So hopefully I can match it all this time around with the exception of the HMIC frame and the heatshield for the fuel cell. Niether of those I can fit in my over.
I don't think there is a way as the heat will probably do some damage to the internals. RattlecanJohnny to the rescue for me for the WP. Housing I coated though
I'd be curious as well. My thinking is electrical conductivity or corrosian resistance.
Old 03-02-2011, 11:49 AM   #23
To_Slow
That is correct...
My link
Old 03-02-2011, 08:53 PM   #24
I dropped off a few more pieces to get oxidized today.
-the bracket that holds the clutch line to the firewall
-the metal brake booster line and the clamp that bolts it to the firewall
-the box that the stock coils are mounted in (I've decided to move them back to the stock location).
You're sending your stuff to Premier or you're just saying you're doing the same thing?
Well my engine is going to be black and gunmetal/dark grey, so if there are a few shades of black/grey I won't mind HAHA. They said if it was anodized it would come out a little lighter than black, but that's OK. I'm still thinking about just getting all the remaining stuff powdercoated though. So would powder coating damage the water pump too? Is that what you're saying?
That is correct...
Gotcha.
