Old 12-03-2010, 11:28 AM   #16
I have a question I will interject here.
Has anyone used ditched the turbo's on an REW, and just run it NA?
I would be interested to see what it would do, either with stock rotors, or high compression rotors.
We did on Paul Ko's old race FC...
We only got 140 on a DynoJet, but we couldn't rev past 6kRPM due to ignition break-up.
Old 12-03-2010, 12:17 PM   #17
RX200013B
RX200013B's Avatar
RX200013B is on a distinguished road
what were the spec of the motor?
ULTIMATE N/A
RX200013B is offline   Reply With Quote
Old 12-03-2010, 11:20 PM   #18
Originally Posted by RX200013B
for ITB's, would 4 38mm throttle be big enough?
for a SP or even a half-bridge?
I don't know what manifold you would be using, but I think that 38mm would be a little small for the secondaries (plenty for the primaries).
I saw a couple builds and they both were using 3 48mm TBs, one for the two primary ports and one for each secondary port.
3 44s would probably be sufficient.
This flows about the same as 4 38s, but the flow into the secondary ports is a lot higher than the flow into the primaries and needs the throttle sizing to be correct.
